Servicio ITS
  • belen6183
    • 12
    Servicio ITS
    Buenas Tardes!!
    Estoy intentando configurar el servicio WEBGUI que pertenece al servicio de ITS para la version 6.0
    En la version 5.0 me funciona pero en la 6.0 no.
    Los servicios estan todos activos en la SICF, nose si al ITS le falta algun parametro o alguna clase.
    Cuando ejecuto el servicio WEBGUI me tirra error de usario.
    Alguien tiene idea de que puede pasar? O algun manual que me ayude a poder terminar la configuracion?
    Muchas Gracias!!!
  • johangonz
    • 816
    Ejecuta la transaccion SIAC_PUBLISH_ALL_INTERNAL y luego intenta nuevamente.
    Debes poner el error porqué es IMPOSIBLE ayudarte sin mostra nada
    Johan González
    CEO
    NW Consulting Services
    www.nwcs.website
    Moderador www.mundosap.com
    • belen6183
      • 12
      Hola Johan
      Te paso el error que me da cuando ejecuto el webgui
      Error when processing your request
      What has happened?
      The URL http://srvsap60.protech.local:8000/s...hourglass.html was not called due to an error.
      Note
      The following error text was processed in the system DEV : Log on with a dialog user
      The error occurred on the application server srvsap60_DEV_00 and in the work process 0 .
      The termination type was: ERROR_MESSAGE_STATE
      The ABAP call stack was:
      Module: %_HTTP_START of program SAPMHTTP
      What can I do?
      If the termination type was RABAX_STATE, then you can find more information on the cause of the termination in the system DEV in transaction ST22.
      If the termination type was ABORT_MESSAGE_STATE, then you can find more information on the cause of the termination on the application server srvsap60_DEV_00 in transaction SM21.
      If the termination type was ERROR_MESSAGE_STATE, then you can search for more information in the trace file for the work process 0 in transaction ST11 on the application server srvsap60_DEV_00 . In some situations, you may also need to analyze the trace files of other work processes.
      If you do not yet have a user ID, contact your system administrator.
      Error code: ICF-IE-http -c: 000 -u: SAPSYS -l: E -s: DEV -i: srvsap60_DEV_00 -w: 0 -d: 20100622 -t: 130604 -v: ERROR_MESSAGE_STATE -e: Log on with a dialog user
      HTTP 500 - Internal Server Error
      Your SAP Internet Communication Framework Team
      • johangonz
        • 816
        Belen?
        Con que usuario te estás intentando loguear? Que tipo de usuario es ese usuario? Servicio?
        Originalmente publicado por belen6183
        Johan González
        CEO
        www.nwcs.website
