Error al instalar Sap IDES 6
  • otsuaf87
    Buen día, en estos momentos estoy tratando de instalar SAP ECC v6.0 SR3 IDES Oracle 10.2.0.2 el instalador de SAP Inst realiza el proceso de creación base de datos, tablas, pero en la comprobación del patch de Oracle se genera un erros, coloco a su disposición el log que se generó.
    Agradezco su pronta colaboración.
    INFO 2016-02-02 05:09:37.234
    Creating file C:\Program Files\sapinst_instdir\x.
    Removing file C:\Program Files\sapinst_instdir\x.
    INFO 2016-02-02 05:09:56.015
    Creating file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\x.
    Removing file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\x.
    INFO 2016-02-02 05:09:59.781
    INFO 2016-02-02 05:10:02.218
    Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.27.xml'.
    INFO 2016-02-02 05:10:06.437
    Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.28.xml'.
    WARNING 2016-02-02 05:10:20.375
    Unable to get information about path \\LABEL.ASC\ using GetVolumeInformation. Operating system error message: The filename, directory name, or volume label syntax is incorrect.
    INFO 2016-02-02 05:10:25.125
    Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/inifile.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/inifile.11.xml'.
    INFO 2016-02-02 05:10:25.546
    Execute step
    Component W2K_ServicePack_Check|ind|ind|ind|ind
    Preprocess of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_First_Step s|ind|ind|ind|ind|0|0|W2K_ServicePack_Check|ind|in d|ind|ind|2|0
    INFO 2016-02-02 05:10:39.671
    Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/keydb.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/keydb.10.xml'.
    INFO 2016-02-02 05:10:39.843
    Copied file 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.xml' to 'C:/Program Files/sapinst_instdir/ERPEhP4/LM/COPY/ORA/SYSTEM/CENTRAL/AS-ABAP/statistic.29.xml'.
    INFO 2016-02-02 05:10:39.921
    Execute step CheckOraclePatchInstalled of component |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_Sy stem|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|in d|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW_ OraDBCheck|ind|ind|ind|ind|0|0|NW_OraDBMain|ind|in d|ind|ind|0|0|NW_OraDBStd|ind|ind|ind|ind|3|0|NW_O raPatch|ind|ind|ind|ind|10|0
    INFO 2016-02-02 05:10:44.640
    Removing file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\ora_query3_tmp0_1.sql.
    INFO 2016-02-02 05:10:44.656
    Creating file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\ora_query3_tmp0_1.sql.
    INFO 2016-02-02 05:10:44.750
    Switched to user: zapadm.
    Working directory changed to C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP.
    INFO 2016-02-02 05:10:44.843
    INFO 2016-02-02 05:10:44.968
    ERROR 2016-02-02 05:10:45.125
    CJS-00084 SQL statement or script failed. DIAGNOSIS: Error message: ORA-16032: parameter LOG_ARCHIVE_DEST destination string cannot be translated
    ORA-09291: sksachk: invalid device specified for archive destination
    OSD-04018: Unable to access the specified directory or device.
    O/S-Error: (OS 3) The system cannot find the path specified.
    Disconnected
    . SOLUTION: For more information, see ora_sql_results.log and the Oracle documentation.
    MUT-03025 Caught ESAPinstException in Modulecall: ORA-16032: parameter LOG_ARCHIVE_DEST destination string cannot be translated
    Disconnected
    FCO-00011 The step CheckOraclePatchInstalled with step key |NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Onehost_Sy stem|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|in d|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW_ OraDBCheck|ind|ind|ind|ind|0|0|NW_OraDBMain|ind|in d|ind|ind|0|0|NW_OraDBStd|ind|ind|ind|ind|3|0|NW_O raPatch|ind|ind|ind|ind|10|0|CheckOraclePatchInsta lled was executed with status ERROR ( Last error reported by the step :Caught ESAPinstException in Modulecall: ORA-16032: parameter LOG_ARCHIVE_DEST destination string cannot be translated
    Disconnected
    INFO 2016-02-02 07:11:53.281
    An error occured and the user decided to stop.\n Current step "|NW_ABAP_OneHost|ind|ind|ind|ind|0|0|NW_Oneho st_S ystem|ind|ind|ind|ind|1|0|NW_CreateDBandLoad|ind|i nd|ind|ind|10|0|NW_CreateDB|ind|ind|ind|ind|0|0|NW _OraDBCheck|ind|ind|ind|ind|0|0|NW_OraDBMain|ind|i nd|ind|ind|0|0|NW_OraDBStd|ind|ind|ind|ind|3|0|NW_ OraPatch|ind|ind|ind|ind|10|0|CheckOraclePatchInst alled".
    INFO 2016-02-02 07:12:17.828
    Creating file C:\Program Files\sapinst_instdir\.lastInstallationLocation.
    INFO 2016-02-02 07:12:18.000
    Creating file C:\Program Files\sapinst_instdir\ERPEhP4\LM\COPY\ORA\SYSTEM\C ENTRAL\AS-ABAP\__instana_tmp.xml.
    gracias.
  • SidV
    Usuario Avanzado
    • 1761
    De dónde lo descargaste?
    No estará mal el instalador?
