Programar aviso de entrada de un material al almacén
  • Junior Member
    Hola buenas noches a tod@s:
    Me gustaría saber si hay alguna forma de programar un aviso de cuando tengo un material en falta para una orden de reparacion y entra stock en almacén.
    Me gustaría poder parámetrizar los materiales en falta para mis ordenes y que me avise cuando entre.
    Muchas gracias, de un novato.
  • Member
    • 33
    Re: Programar aviso de entrada de un material al almacén
    Si si utilizas WM, en la creación de Ordenes de transporte (TO/OT).
    la TX LT51 te permite crear listas de faltantes, donde, cuanto, etc.
    Y a medida que en la entrada descuentas las faltas la cantidad faltante se reduce. Sin embargo, no lo hace automático. Requiere de mantenimientos manuales.
    Ve la información siguiente: (Crossdocking)
    Stock Placement with Active Bypass
    The system activates the active bypass, when it identifies a "pre-allocated" material in a stock placement transfer order. The material is not placed in reserve storage but is routed directly from the goods receipt interim storage area to the destination that you have specified in the stock-out table.
    When you create the transfer order for stock placement, the system looks at the movement type record to determine if it should check the material for pre-allocated stock.
    If the pre-allocated stock indicator is set for the movement type, the system then checks the stock-out table. Data about stock that has already been allocated to fill an order is stored in this table.
    If the material is listed in the stock-out table, the system activates the active bypass and displays a message on the Transfer Order Preparation screen to inform you that the material is pre-allocated stock.
    Procedure
    From the preparation screen for creating a transfer order choose Pre-allocated stock.
    The system displays the information in the stock-out table for the material. The pushbuttons on this screen allow you to select, deselect and delete entries and adopt open quantities that are to be processed.
    On the pre-allocated stock screen you can enter a quantity in the Selected qty field or mark a line and choose the Calculate selected quantity icon.
    If you select the Calculate icon, the system copies the open quantity in the stock-out table into the Selected qty field. However, if the quantity needed for the TO is less than the quantity in the stock-out table, the system enters the smaller quantity into the Selected qty field and reduces the stock-out table quantity accordingly when you post the data to the database.
    To create the transfer order item, choose either Edit ® For stock placement ® Foreground or Edit ® For stock placement ® Background.
    Once you have finished creating the transfer order items, save the transfer order to the database.
    If the quantity is equal to or more than the quantity entered in the stock-out table, the system removes the entry from the table when you confirm the transfer order.
    Ya hace 4 años que estoy retirado... y no tengo acceso a SAP alguno, asi que no tengo chances de darte mayor información, como por ejemplo verificar si existe también si no utilizas el módulo de WM
    Saludos cordiales
    Daniel B.Coria
    SAP SCM Certified Consultant
    MM/WM
