Hola a todos necesito que me ayuden :
Resulta que estoy pagando a 800 acreedores,los cuales tienen retencion de impuesto, luego de seleccionar las partidas abiertas cuadra el asiento pero cuando intento grabar el asiento me sale el siguiente error :
Segun consulte, por ahi me dijeron que se trata de una partida abierta con valor cero,pero revisando todas las partidas que selecciono no hay ninguna con ese valor , por favor me podrian ayudar ...
Atentamente
Alex Torres
Runtime Errors CONVT_NO_NUMBER
Exception CX_SY_CONVERSION_NO_NUMBER
Date and Time 13.05.2008 09:53:39
|Short text |
| Unable to interpret "*0" as a number. |
|What happened? |
| Error in the ABAP Application Program |
| The current ABAP program "SAPLFWTH" had to be terminated because it has |
| come across a statement that unfortunately cannot be executed. |
|What can you do? |
| Note down which actions and inputs caused the error. |
| To process the problem further, contact you SAP system |
| administrator. |
| Using Transaction ST22 for ABAP Dump Analysis, you can look |
| at and manage termination messages, and you can also |
| keep them for a long time. |
|Error analysis |
| An exception occurred that is explained in detail below. |
| The exception, which is assigned to class 'CX_SY_CONVERSION_NO_NUMBER', was not |
| caught in |
| procedure "FI_WT_COLLECT_KONTAB" "(FUNCTION)", nor was it propagated by a |
| RAISING clause. |
| Since the caller of the procedure could not have anticipated that the |
| exception would occur, the current program is terminated. |
Atentamente
Alex Torres
|Short text |
|What happened? |
|What can you do? |
| administrator. |
|Error analysis |
| caught in |
| RAISING clause. |
