Estas son las notas que se encontramos para la configuracion de cd los CFDs
1109487 New Qualifier Values for Idocs Basic Type INVOICE02
1279680 MX: IMG Structure for ODN and Prenumbered Forms
1280467 FAQ Digital Invoice Mexico
1296042 Digital Invoice Mexico XML file generation in PI
1300880 Digital Invoice Mexico: Import Certificates
1301160 ODN enabled in SD and FI for Mexico for digital invoicing
1303712 Mexico: Enable Creation of Digital Signature in SD and FI
1318342 Digital Invoice Mexico: IDoc basic type INVOIC02 Extension
1321680 Digital Invoice Mexico: IDoc basic type FIDCCP02 Extension
1332622 Reference XBLNR not required in cancellation document for MX
1338485 Digital Invoice Mexico: monthly report/file
1339487 Reference XBLNR not required in cancelled credit memo for MX
1348039 Correction to note 1301160 (Valid for release 46C,4.70)
1359477 Checking format for ODN without prefixes for Mexico
1357003 Digital Invoice not posted to accounting
1365263 Free of charge items in digital invoices
1365961 BADI Change to incorporate Billing type for Mexico
1368391 Digital Invoice Mexico Signing with a Windows server
1368701 Digital Invoice Mexico Customizing
1370439 Customer and company name length in the digital invoice
1371218 Digital Invoice Mexico: report-manual invoices in FI
1371612 Date control and chronological numbering of digital invoices
1372605 Digital Invoice Mexico: Validation of the XML file fails
1372621 Digital Invoice including withholdings with zero amount
1373594 Multiple customs documents per line item
1378058 Digital Invoice Mexico: monthly report performance
1383114 Digital Invoice in FI and One-Time-Customer
1384016 Digital Invoice Mexico: wrong MD5 hash value displayed
1386881 Digital Invoice Mexico: non-unicode-double-byte-code
1390034 Direct Consecutive Blanks in the Original Input Message
1390119 Digital Invoice Recipient with ten-digit Postal Code
1393928 Digital Invoice Mexico: invoices with zero amounts only
1395923 BADI Change to incorporate Net Amount(VBRK-NETWR) for Mexico
1399365 Mexican digital invoices in FI and tax amount differences
1408686 Customs data replication in FI digital invoices
1406649 Digital Invoice Mexico: formats of lines in text table
1419063 Tax totals do not match in the original input message
1420159 DI Mexico: monthly report - credit memo
1425498 Digital signature with tax code activating several tax types
1428090 Digital invoices and " Anexo 20 de la RMF para 2009 "
1429706 Digital Invoice Mexico: Validity Period of an PSE-file
1429844 Cancelled invoices appearing in the digital invoice report
1440384 Installment Payments and Digital Invoices
1442555 Short Dump when Creating Mexican Digital Invoices
1444871 Digital Invoice Mexico: wrong credentials for pse-file
1444885 Wrong approval number in digital invoices
1447651 Approval number and Monthly report
1464579 Message IDMX440 is raised when running billing in background
1452609 Digital Invoice Mexico: customer tax identification number
1313457 IDoc - Invoice: E1EDK02 - Reference document number missing
1528021 Mexico 2011 Modificaciones a la Resolución Miscelánea Fiscal
1511307 Electronic Documents for Mexico
Pero estas son las que usamos para nuestro caso: ya que solo generamos los cfds desde SD VF01.
Si gustas tambien puedo compartirte lo que SAP presento sobre facturacion, es un pdf de 3mb con 50 hojas.
Me avisas si te interesa para mandartelo a algun correo.
podrias compartirlo por favor,
Se borra correo personal
muchas gracias
____________________
J Roberto Amaya Rodriguez / Grupo Pecuario San Antonio / Departamento de Consultoria / robertoamayar@hotmail.com / Cordoba,Ver - Mexico
Buenas tardes!
Tengo algunas dudas en cuanto al manejo de factura electronica dentro de SAP.
Estamos en un proceso de implementación de SD en la empresa en la que laboro.
Actualmente el ERP que tenemos tiene el control y asignación de folios y series a las facturas , notas de credito y notas de cargo y por una interfase a otro sistema se genera el sellado y generado de xml asi como el respaldo .
Mi duda es si se puede manejar de la misma forma con SAP, osea que el siga administrando la asignación de series y folios y que por medio de una interfas detecte la generación de un documento y se envio creo que por IDOC´s al sistema de sellado y generado de xml .
Ustedes me podrian apoyar con este tema o podran compartirme sus experiencias con este tema .
Cabe la posibilidad de generar el sellados en otro lado ya que yo estuve generando los idocs incompletos sin el sello, y pues con la numeracion, y pues generar lo demas en otro software, pero si se tiene que programar la generacion del idoc y pues la lectura del mismo.
Y pues si ya tienes SAP lo reconmedable es que lo hagas todo de ahi, para no andar de un sistema a otro.
Gracias y Salduos!
Hola Fabiola
Claro que se puede, el problema aqui es a otro nivel; debido a que tu sistema se encuentra sellando las facturas mediante un esquema de un tercer proveedor, si tu quisieras cambiar de esquema de forma que no dependas de un tercero ya no podras hacerlo.
Primero. Lo que recuerdo es que Hacienda (SAT) ha dado la indicación de que todas las empresas que tienen a un proveedor tercero para la creacion del sello fiscal, deben de cambiar ahora al esquema de CFDi (creo que a partir de Junio del 2011 deberian estar en este esquema o algo asi).
El uso de CFDi, te lleva a que a parte de que debes crear el sello fiscal, ahora se debe de crear un timbre fiscal, el cual solo puede ser proporcionado unica y exclusivamente por un proveedor tercero, lo que nos lleva a donde iniciamos.
Si no sabes desarrollarte a ti mismo, nadie lo hara por ti....
