Withholding tax MX
  • MuenchnerFreiheit
    • 6
    Withholding tax MX
    Buenos días!
    I am trying to set up extended withholding tax in our new client in Mexico for the first time. Using SAP HELP and the manual from the sapficoconsultant site, I have have followed all the steps, complete the all possible configuration and also filled out the relevant information it the Vendor Master Data. Now while posting vendor invoice with TC FB60/ F-43/FB01, system not deducting WT tax even the vendor relevant to extended withholding tax.
    When entering a document, the withholding tax dialog box with tax code and tax type is shown, but tax base amount and WT amount are not filled.
    I have been through the configuration steps many time and got nothing cleared. I don'n know where else I need to look into.
    Steps I followed:
    1- Check WH Tax Countries --> Mexico MX
    2- Define official WH Tax Codes (IVA, ISR)
    3- Define recipient types (rent vendors, proffesional fees, transportation)
    4 - Define WH Tax Type for Invoice posting (tax base - net amount, post WT amount, w/o accumulation, w/o min/max amounts, tax.base manual, tax manual, no cert.)
    5- Define WH Tax Codes (posting indicator 1), for ISR 10% and for IVA 10,66%.
    6- Assign WH Tax Types to our Company Code (validaty period 01.01.2000 - 31.12.9999)
    7- Define GL Accounts for WH Tax to be paid over
    8- Activate Extended WH Tax
    9- Fill out WH Tax settings in Vendor master Record, "Liable" option is checked in Vendor Master, WH Tax Type and Code entered.
    BUT IT DOES'T WORK.. .Because something else is missing, I presume..
    Can anybody help me to find out the mistake? Is there any other setting I should configure?
    I will much appreciate if you could give me a hand.
    Many thanks in advance!
    Kind regards,
    FICO
    P.S. Also while posting EWT related transaction system don't show any error or warning message.
  • guly23
    • 33
    Retencion de Impuestos
    In your master data did you define your the withholding tax type, the posting at time of invoice?
    In the Extenden Withholding Tax...
    You can check it there. I am online if you want we can try to search the error.
    jc_sr@hotmail.com
    • MuenchnerFreiheit
      • 6
      Hello!
      So many thanks for the respond!
      Unfortunatelly I am not in the office at the moment, is is 21.00 in Germany .
      Could we pls check it tomorrow?
      I'm really sorry to bother you and I'm sorry for my English on this forum but I really need help...
      • guly23
        • 33
        kein problem
        Ach so kein problem, üder meine Deutsch is nicht gut auch, aber wir kannt morgen ein wissen sprechen ums MSN. Bis Morgen
        • MuenchnerFreiheit
          • 6
          Hola!
          It is quite difficult to speak, because all possible communication tools are blocked at the office. I could make screenshots of my customizing settings and send it to your email. It is possible?
          Grüße,
          FICO
          • guly23
            • 33
            Ok
            sent it to my mail
            • RAFAX
              • 37
              Posting keys
              I think your problem might be caused because the withholding tax code and withholding tax fields are set up as supressed. I would recommend you to run transaction OB41 and check the field status group for the posting keys you are using to enter the invoice (e.g. posting key '31' for vendor invoice). If you select the 'Taxes' group make sure that the fields 'Withholding Tax Code' and 'Withholding Tax amounts' are set up as optional entry instead of supressed.
              • MuenchnerFreiheit
                • 6
                Originalmente publicado por RAFAX
                I've checked it - these fields are optional. Maybe any other settings could be wrong?
                • RAFAX
                  • 37
                  G/L Reconciliation account
                  The next check I would suggest to make is to find out the number of the G/L reconciliation account that is set up for the vendor that you want to post the invoice (field LFB1-AKONT). Next, find out which field status group is assigned to that G/L reconciliation account (field SKB1-FSTAG). Finally, run OBC4 and make sure that the field status group has the fields 'Withholding Tax Code' and 'Withholding Tax amounts' set up as optional entry instead of supressed.
                  • MuenchnerFreiheit
                    • 6
                    #10
                    I have checked it - all this fields are set up as optional...
                    • RAFAX
                      • 37
                      #11
                      Alternatives
                      Running report RFWT1000 may help to find the root cause.
                      OSS Notes 546564, 127352, 310856 provide guidance.
                      • MuenchnerFreiheit
                        • 6
                        #12
                        Thank you so much! I will check it.
