Mensaje de sistema 06152
  • Crisr
    • 28
    Hola, estoy configurando el mensaje 06152 como Error (esta en warning) desde spro-Gestión de materiales-Compras-Datos de entorno-Especificar propiedades de mensajes de sistema, y no me lo esta tomando en las solicitudes de pedido..., me sigue quedando como warning...
    que puede ser???
    Saludos.-
  • kili
    • 9
    Mensaje 06152
    Esta fue la respuesta de a una note que se coloca en SAP en relacion a este problema.
    09.01.2008 - 22:53:10 CET****SAP****Reply
    Dear customer:
    The message 06152 is a hard-coded Warning message and it cannot be
    configured as an Error message in OME0.
    There are certain cases where making this message appear as an error
    would make sense, but there are customers who want to be able to
    delete a Requisition item despite the fact that there has been a
    Purchase Order created against it. Thus, an Error message would be
    too strict.
    Therefore you only have the possibility to modify the program (e.g. by
    changing the line MESSAGE W152 to MESSAGE E152). Please be aware that
    this is considered a modification, and will not be supported by SAP.
    There had already been a development request regarding this subject,
    but our development department rejected the realization of this
    request with the following statement:
    There is no technical need for an error message. Also from a business
    point of view there is no need for an error message. The user does
    just the same, the archiving program will do after a while. The process
    is well documented, so it is visible that the deletion is done after
    the requisition is purchased.
    I hope this explains clearly how the standard system is designed.
    Please close this message by confirming it.
