Editor de texto vacío al intentar modificar elemento
  • Faramur
    Estimados
    Tengo un problema en el cuál al intentar modificar un elemento de texto, este no se despliega en la ventana del editor. Sin embargo, si presiono el botón de Editor Txt, este elemento si se visualiza.
    ¿Alguien ha tenido un problema similar o tendrá alguna noción de que podría ser?
    Tengo la versión GUI 7.6 y en todos los clientes sucede lo mismo.
    Muchas gracias por cualquier ayuda!
  • julmungal
    • 25
    Buenas.
    En la nota 2221815: SAPscript Legacy Text Editor controls are not packed in SAP Windows GUI Installation; viene explicado que necesitas un parche para arreglarlo, además de las antiguas versiones desde la 7.40:
    For GUI 7.60
    The SAP Support Portal page focused on the SAP Software Download Center is the central location to download your company’s SAP software. You can download the SAP products that are associated with your S-user ID. While every visitor can browse the list of software products without any special permissions, downloading files requires the Software Download authorization; to request it, contact a user administrator in your company.
    -> Support Packages and Patches
    -> Click on tile 'Software Downloads' which starts the Lauchpad
    -> In the header select 'SUPPORT PACKAGES & PATCHES'
    -> Select 'By Category'
    -> SAP Frontend Components
    -> SAPSCRIPT LEGACY TEXT EDITOR
    -> SCR LEGACY TEXT EDITOR GUI7.60
    The downloaded 'SAPSCRIPT LEGACY TEXT EDITOR' should be installed additionally on SAP Windows GUI 7.50.
    The existing SAP GUI Installation Server Configuration can be extended with component 'SAPSCRIPT LEGACY TEXT EDITOR' by following steps:
    - Download 'SAPSCRIPT LEGACY TEXT EDITOR' from SAP Software Download Center
    - Extract the installer’s content in one folder, by calling the installer file from command line with the option /extract=”<FOLDER_NAME>”
    e.g. SAPSLTESP00_0-70001053.EXE /extract=”SAPscriptEditor”
    (This example will create a folder named ”SAPscriptEditor” and extract the installer’s content into it.)
    - Start NWSAPSetupAdmin.exe from the SETUP directory of the installation server
    - Push the Import Products in toolbar
    - Follow the wizard and supply the path to the source containing the extracted product to be added to the installation server.
    e.g. SAPscriptEditor/Setup
    SAPscript Legacy Text Editor is an obsolete component, it was replaced by "MS Word as SAPScript Text Editor". You can find more information in the note 742662.
    For using of Graphical Painter by development of SAPscript Forms (Transaction SE71), the SAPscript Legacy Text Editor controls component should be installed additionally to SAP Windows GUI.
    • Junior Member
      • 5
      Re: Editor de texto vacío al intentar modificar elemento
      Tuve exactamente el mismo problema. Lo solucioné con este parche:
      SCRLTESP76000_0-80004481.EXE
      Acá encontré la descarga:
      https://launchpad.support.sap.com/#/softwarecenter/template/products/_APP=00200682500000001943&_EVENT=DISPHIER&HEADER=Y &FUNCTIONBAR=N&EVENT=TREE&NE=NAVIGATE&ENR=73554900 100100001935&V=MAINT
      Cabe señalar que igual buscando la solución instalé hasta el patch 8 de SAPGUI760, pero no resolví el problema hasta el parche que mencioné antes.
      Slds.
      Luis Saavedra C.
      • Junior Member
        Muchísimas gracias por la respuesta.
        Editado por última vez por mcvision_; 02/11/2021, 12:12:55.
        • Junior Member
          Otra cosa: al instalarlo, el editor de lo que son las líneas de comando ahora es más complicado al tener tratarlo línea a línea como un texto, cuando antes se podía tratar como cualquier código abap, con sus colores, propuestas, pudiendo seleccionar más de una linea....
          ¿Eso es lo normal?
          • Junior Member
            No me lo explico:
            Tras varios días en los que me pasó eso, hoy la máquina amaneció de buenas y ya no tengo ese problema y ya no supone un engorro el añadir líneas de ABAP
            • Junior Member
              Buen dia a todos! Alguien tiene el instalador que me lo pueda pasar.
              He intentado descargarlo del MarketPlace pero ya no se encuentra disponible.
              Atte.
              Alex
