Hola gente tengo un problemon, resulta que toy haciendo un smartform y el programa se cierra con un DUMP con la siguiente excepcion
Errores tiempo ejecución BCD_BADDATA
>> Dump breve ABAP no almacenado completamente (muy grande)
Packed field contains incorrect BCD format.
Análisis error
An arithmetic operation in the current program "/1BCDWB/SAPLSF00000020 "
attempts
to process a field of type P that contains an invalid
BCD format.
Possible reasons:
1. If the field is part of a field string and its current contents are
hex 20: the field string was deleted with MOVE SPACE ... instead of
CLEAR.
2. The VARYING parameter was incorrectly placed within a DO loop,
e.g. because the TIMES parameter was too large.
Similar for WHILE ... VARY.
3. A FIELD-SYMBOL was incorrectly assigned.
Yo paso como parametro al smartform una tabla con un campo de tipo P con 2 decimales ... ojala alguien me pueda ayudar
PD: Adjunto la imagen del debugg
Análisis error
attempts
BCD format.
Possible reasons:
CLEAR.
