Hola a todos.
Necesito ayuda. El problema que tengo es que me da un dump cuando hago una llamada a una función en background. Necesito que sea en back porque tiene que esperar a que se desbloqueen unos objetos para que haga un BI.
Esta es la llamada.
CALL FUNCTION 'ZREVALORIZACION_MATERIALES' IN BACKGROUND TASK
* CALL FUNCTION 'ZREVALORIZACION_MATERIALES' IN UPDATE TASK
w_mseg = w_mseg.
Tengo comentado todo lo que hace dentro de la función y me da un dump por lo que el error es en la llamada. Os copio el dump en cuestión.
Errores tiempo ejec. PERFORM_PARAMETER_MISSING
Excepción CX_SY_DYN_CALL_PARAM_MISSING
Fecha y hora 04.09.2008 14:12:44
¿Qué ha sucedido?
A routine call specifies fewer parameters than the number
given when defining the routine.
Anál.errores
An exception occurred that is explained in detail below.
The exception, which is assigned to class 'CX_SY_DYN_CALL_PARAM_MISSING', was
not caught in
procedure "XAB_RUN_DRIVER" "(FORM)", nor was it propagated by a RAISING clause.
Since the caller of the procedure could not have anticipated that the
exception would occur, the current program is terminated.
The reason for the exception is:
A PERFORM was used to call the routine "XAB_RUN_DRIVER" of the program
"SAPMSSY1".
The current call contains 0 actual parameter(s),
but the routine "XAB_RUN_DRIVER" expects more than 0 parameters.
parameters.
Codigo
data : subrc type i.
call 'AB_GET_C_PARMS' id 'P1' field <prog> "Programmname
id 'P2' field <cntl>. "Handle
perform rfcdrv_rflush in program (<prog>) using <cntl>
subrc
if found.
call 'AB_SET_C_PARMS' id 'P2' field <cntl>. "Handle
syst-subrc = subrc.
endform.
form xab_run_driver using prog type c
if_found type i
new_function type c.
data : program like syst-repid.
program = prog.
if new_function = space.
call 'RfcImport' id 'Push' field rfctype_abap4_exit
id 'Info' field program.
else.
id 'Function' field new_function.
endif.
if if_found = 0.
perform (sy-xform) in program (sy-xprog).
else. FALLO AQUI
perform (sy-xform) in program (sy-xprog) if found.
endif.
endform.
Alguien sabe que puede ser???
Muchas gracias!
Esta es la llamada.
w_mseg = w_mseg.
¿Qué ha sucedido?
Anál.errores
not caught in
"SAPMSSY1".
parameters.
Codigo
subrc
if found.
syst-subrc = subrc.
endform.
if_found type i
program = prog.
else.
endif.
if if_found = 0.
else. FALLO AQUI
endif.
endform.
Muchas gracias!
