If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Hola ... creo lo mejor es que revises todos los programas en la SE38 que comienzen con BCALV* ... asi aprendi a usar los objetos para crear ALV's entre otras aplicaciones
