error: stamente is not accessible
  • akiestudio
    • 46
    Hola buenas estoy haciendo unas pruebas para iniciarme en este mundo de abap y resulta que me dice este error de stament is not accesible en las lineas de que he subrayado en negrita y no se cual puede ser el problema , alguna ayuda gracias
    DATA: IT_SFLIGHT TYPE TABLE OF SFLIGHT,
    HE_SFILGHT LIKE LINE OF it_sflight.
    DATA: IT_TABLA TYPE LVC_T_FCAT,
    HE_TABLA LIKE LINE OF IT_TABLA.
    DATA: CONTENEDOR TYPE REF TO CL_GUI_CUSTOM_CONTAINER,
    ALV TYPE REF TO CL_GUI_ALV_GRID.
    * ESTO MEJORA LA ESTETICA DE LA TABLA
    DATA: LAYOUT TYPE LVC_S_LAYO.
    *CREAMOS LOS OBJETOS
    create object contenedor
    exporting
    container_name = 'CONTENEDOR DE TABLAS'.
    * style =
    * lifetime = lifetime_default
    * repid =
    * dynnr =
    * no_autodef_progid_dynnr =
    * exceptions
    * cntl_error = 1
    * cntl_system_error = 2
    * create_error = 3
    * lifetime_error = 4
    * lifetime_dynpro_dynpro_link = 5
    * others = 6
    create object alvexporting
    * i_shellstyle = 0
    * i_lifetime =
    i_parent = CONTENEDOR.
    LAYOUT-ZEBRA = 'X'.LAYOUT-SEL_MODE = 'C'.
    *CARGAMOS LAS TABLAS CON LOS CAMPOS DESEADOS
    HE_TABLA-FIELDNAME = 'CARRID'.HE_TABLA-REF_TABLE = 'SFLIGHT'.
    APPEND HE_TABLA TO IT_TABLA.
    CLEAR HE_TABLA.
    HE_TABLA-FIELDNAME = 'CONNID'.
    CLEAR HE_TABLA.
    HE_TABLA-FIELDNAME = 'FLDATE'.
    APPEND HE_TABLE TO IT_TABLA.
    CLEAR HE_TABLA.
    HE_TABLA-FIELDNAME = 'PRICE'.
    CLEAR HE_TABLA.
    HE_TABLA-FIELDNAME = 'CURRENCY'.
    ÀPPEND HE_TABLE TO IT_TABLA.
    CLEAR HE_TABLA.
    SELECT * FROM SFLIGHT INTO TABLE IT_SFLIGHT.
    call method alv->set_table_for_first_display
    * exporting
    * i_buffer_active =
    * i_bypassing_buffer =
    * i_consistency_check =
    * i_structure_name =
    * is_variant =
    * i_save =
    * i_default = 'X'
    * is_layout =
    * is_print =
    * it_special_groups =
    * it_toolbar_excluding =
    * it_hyperlink =
    * it_alv_graphics =
    * it_except_qinfo =
    * ir_salv_adapter =
    changing
    it_outtab =
    * it_fieldcatalog =
    * it_sort =
    * it_filter =
    * exceptions
    * invalid_parameter_combination = 1
    * program_error = 2
    * too_many_lines = 3
    * others = 4
    if sy-subrc <> 0.
    * MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
    * WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
    endif.
    *& Module PBO_SFLIGHT OUTPUT
    * text
    module PBO_SFLIGHT output.
    SET PF-STATUS PBO_SFLIGHT.
    endmodule. " PBO_SFLIGHT OUTPUT
    *& Module PAI_SFLIGHT INPUT
    * text
    module PAI_SFLIGHT input.
    SA_CODE = OK_CODE.
    CLEAR OK_CODE.
    CASE SA_CODE.
    WHEN 'BACK' OR 'CANCEL' OR 'EXIT'.
    LEAVE PROGRAM.
    ENDCASE.
    endmodule. " PAI_SFLIGHT INPUT
  • akiestudio
    • 46
    Todo resuelto con un start-of-selection , y un end-of-selection , se resolvio .
