report zuserexit_proba no standard page heading.
tables : tstc, tadir, modsapt, modact, trdir, tfdir, enlfdir.
tables : tstct.
data : jtab like tadir occurs 0 with header line.
data : field1(30).
data : v_devclass like tadir-devclass.
parameters : p_tcode like tstc-tcode obligatory.
select single * from tstc where tcode eq p_tcode.
if sy-subrc eq 0.
select single * from tadir where pgmid = 'R3TR'
and object = 'PROG'
and obj_name = tstc-pgmna.
move : tadir-devclass to v_devclass.
if sy-subrc ne 0.
select single * from trdir where name = tstc-pgmna.
if trdir-subc eq 'F'.
select single * from tfdir where pname = tstc-pgmna.
select single * from enlfdir where funcname =
tfdir-funcname.
and object = 'FUGR'
and obj_name eq enlfdir-area.
endif.
endif.
select * from tadir into table jtab
and object = 'SMOD'
and devclass = v_devclass.
select single * from tstct where sprsl eq sy-langu and
tcode eq p_tcode.
format color col_positive intensified off.
write:/(19) 'Transaction Code - ',
20(20) p_tcode,
45(50) tstct-ttext.
skip.
if not jtab[] is initial.
write:/(95) sy-uline.
format color col_heading intensified on.
write:/1 sy-vline,
2 'Nombre Exit',
21 sy-vline ,
22 'Descripcion',
95 sy-vline.
loop at jtab.
select single * from modsapt
where sprsl = sy-langu and
name = jtab-obj_name.
format color col_normal intensified off.
write:/1 sy-vline,
2 jtab-obj_name hotspot on,
21 sy-vline ,
22 modsapt-modtext,
95 sy-vline.
endloop.
describe table jtab.
skip.
format color col_total intensified on.
write:/ 'Número de Exits:' , sy-tfill.
else.
format color col_negative intensified on.
write:/(95) 'No existe ninguna user exit'.
endif.
else.
write:/(95) 'El código de transacción no existe'.
endif.
at line-selection.
get cursor field field1.
check field1(4) eq 'JTAB'.
set parameter id 'MON' field sy-lisel+1(10).
call transaction 'SMOD' and skip first screen.
tables : tstct.
data : field1(30).
if sy-subrc eq 0.
and object = 'PROG'
if sy-subrc ne 0.
tfdir-funcname.
and object = 'FUGR'
endif.
endif.
and object = 'SMOD'
tcode eq p_tcode.
20(20) p_tcode,
45(50) tstct-ttext.
skip.
write:/1 sy-vline,
2 'Nombre Exit',
21 sy-vline ,
22 'Descripcion',
95 sy-vline.
loop at jtab.
write:/1 sy-vline,
21 sy-vline ,
22 modsapt-modtext,
95 sy-vline.
endloop.
skip.
else.
endif.
else.
endif.
at line-selection.
Hola Atlas
Gracias por el codigo me sirvio mucho y ya revise mi transaccion sap estandard desgraciadamente no cuenta con un screen exit.
Pero ya cuento con la herramienta para poder saberlo y no perder el tiempo tratando de adivinar si existe o no ....
Hola, quisiera saber como puedo agregar unas pestañas a una dynpro estandar, y por supuesto como asigno los datos de una estructura a esas pestañas. De antemano muchas gracias por la ayuda. Saludos
