Crear datos en infty 2010 via User Exit
  • mdudzin
    Hola, Estoy teniendo problemas para crear datos en el infty 2010.
    Estoy usando el siguiente codigo:
    FORM f_create2010 USING p_pernr p_begda p_endda p_value p_wt.
    DATA: header_assob LIKE assob.
    DATA: l_asshr LIKE asshr.
    DATA: ls_pdsnr LIKE pdsnr.
    DATA: w_pdsnr LIKE asshr-pdsnr,
    w_bukrs LIKE csks-bukrs,
    w_kokrs LIKE csks-kokrs,
    w_gsber LIKE csks-gsber,
    w_seqnr LIKE *pa2010-seqnr.
    DATA: return TYPE bapireturn1.
    DATA: pv_viekn LIKE pa0003-viekn.
    DATA: BEGIN OF p2010 OCCURS 5. INCLUDE STRUCTURE p2010. DATA: END OF p2010.
    DATA: BEGIN OF wa_infty OCCURS 1. INCLUDE STRUCTURE p2010. DATA: END OF wa_infty.
    BREAK-POINT.
    SELECT SINGLE viekn FROM pa0003 INTO pv_viekn WHERE pernr = p_pernr AND begda <= p_begda.
    CALL FUNCTION 'BAPI_EMPLOYEE_ENQUEUE'
    EXPORTING number = p_pernr
    IMPORTING return = return.
    IF return IS INITIAL.
    CALL FUNCTION 'HR_READ_INFOTYPE'
    EXPORTING *
    TCLAS = 'A'
    pernr = p_pernr
    infty = '2010'
    *BEGDA = '18000101'
    *ENDDA = '99991231'
    * BYPASS_BUFFER = ' '
    * LEGACY_MODE = ' '
    * IMPORTING
    * SUBRC = SUBRC
    TABLES infty_tab = p2010.
    LOOP AT p2010 WHERE subty = p_wt. MOVE p2010 TO wa_infty. EXIT. ENDLOOP.
    wa_infty-pernr = p_pernr.
    wa_infty-infty = '2010'.
    wa_infty-lgart = p_wt.
    wa_infty-subty = p_wt.
    wa_infty-stdaz = p_value.
    wa_infty-begda = p_begda.
    wa_infty-endda = p_endda.
    wa_infty-AEDTM = sy-datum.
    wa_infty-UNAME = sy-uname.
    CALL FUNCTION 'HR_INFOTYPE_OPERATION'
    infty = '2010'
    number = p_pernr
    subtype = p_wt
    validitybegin = p_begda
    record = wa_infty
    operation = 'INS'
    view_identifier = pv_viekn
    tclas = 'A'
    dialog_mode = '1'
    IMPORTING
    return = return.
    IF NOT return IS INITIAL AND return-type EQ 'E'.
    MESSAGE e000(38) WITH return-message.
    CALL FUNCTION 'BAPI_EMPLOYEE_DEQUEUE'
    IMPORTING return = return. ENDIF.
    ENDFORM. " F_CREATE2010
    Aparentemente HR_READ_INFOTYPE no funcionaria con el infty 2010.
    ¿Alguno tiene alguna idea?
