problemas con al convercion
  • Hasurac
    • 41
    les pido ayuda para ver porque puede ser que no funcione la convercion a pdf y de hai a binario le s paso el codigo aver si ustedes ven algo que se me paso por alto desde ya gracias
    form gen_pdf changing p_logo lv_solicitud p_nom_tra p_rut_tra p_empresa
    p_fech_ing_emp p_sindicato p_tip_boni p_rut_ben p_nom_hc
    p_ap_paterno p_ap_materno p_001 i_cont_bin numbytes.
    tables nast.
    w_ctrlop-getotf = 'X'.
    w_ctrlop-no_dialog = 'X'.
    w_compop-tdnoprev = 'X'.
    w_compop-tddest = 'LOCL'.
    w_compop-tdarmod = '1'.
    w_compop-tdcopies = '1'.
    w_compop-tdprinter = 'SAPWIN'.
    w_compop-tdlifetime = '8'.
    call function '/1BCDWB/SF00000006'
    exporting
    control_parameters = w_ctrlop
    output_options = w_compop
    user_settings = 'X'
    gp_logo = p_logo "Aca los parametros que necesita el smartform
    gp_n_solicitud = lv_solicitud
    gp_nom_tra = p_nom_tra
    gp_rut_tra = p_rut_tra
    gp_empresa = p_empresa
    gp_fech_ing_emp = p_fech_ing_emp
    gp_sindicato = p_sindicato
    gp_tip_boni = p_tip_boni
    gp_fech_soli = sy-datum
    gp_rut_bene = p_rut_ben
    gp_nom_famil = p_nom_hc
    gp_ap_paterno = p_ap_paterno
    gp_ap_materno = p_ap_materno
    gp_for001 = p_001
    importing
    job_output_info = w_return "aca me devuelve el smartform
    exceptions
    formatting_error = 1
    internal_error = 2
    send_error = 3
    user_canceled = 4
    others = 5.
    if sy-subrc ne 0.
    * MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
    * WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
    endif.
    i_otf[] = w_return-otfdata[].
    CALL FUNCTION 'QCE1_CONVERT'
    * TABLES
    * t_source_tab = i_tline
    * t_target_tab = i_cont
    * EXCEPTIONS
    * CONVERT_NOT_POSSIBLE = 1
    * OTHERS = 2
    * IF sy-subrc <> 0.
    * ENDIF.
    endform. " GEN_PDF
    despues lo envio
    data: objpack like sopcklsti1 occurs 2 with header line.
    data: objhead like solisti1 occurs 1 with header line.
    data: objbin like solisti1 occurs 10 with header line.
    data: objtxt like solisti1 occurs 10 with header line.
    data: reclist like somlreci1 occurs 5 with header line.
    data: doc_chng like sodocchgi1.
    data: tab_lines like sy-tabix.
    data l_num(3).
    * Creation of the document to be sent
    doc_chng-obj_name = 'SENDFILE'.
    * Mail Subject
    doc_chng-obj_descr = 'Prueba de Correo via Sap'.
    * Mail Contents
    objtxt = 'Este es el contenido del mensaje'.
    append objtxt.
    describe table objtxt lines tab_lines.
    read table objtxt index tab_lines.
    doc_chng-doc_size = ( tab_lines - 1 ) * 255 + strlen( objtxt ).
    * Creation of the entry for the compressed document
    clear objpack-transf_bin.
    objpack-head_start = 1.
    objpack-head_num = 0.
    objpack-body_start = 1.
    objpack-body_num = tab_lines.
    objpack-doc_type = 'RAW'.
    append objpack.
    * Creation of the document attachment
    data: saltolinea type x.
    saltolinea = '0D'.
    describe table objbin lines tab_lines.
    objhead = 'PDF'.
    append objhead.
    ** Creation of the entry for the compressed attachment
    describe table i_cont_bin lines tab_lines.
    objpack-transf_bin = 'X'.
    objpack-head_num = 1.
    objpack-doc_type = 'PDF'.
    objpack-doc_size = numbytes.
    move objhead to objpack-obj_descr.
    move objhead to objpack-obj_name.
    objpack-doc_size = tab_lines * 255.
    append objpack.
    clear reclist.
    reclist-receiver = 'XXXXXXXXX@hotmail.com'.
    reclist-express = 'X'.
    reclist-rec_type = 'U'.
    reclist-copy = 'X'.
    append reclist.
    * Sending the document
    call function 'SO_NEW_DOCUMENT_ATT_SEND_API1'
    exporting
    document_data = doc_chng
    put_in_outbox = 'X'
    commit_work = 'X'
    tables
    packing_list = objpack
    object_header = objhead
    contents_bin = i_cont_bin
    contents_txt = objtxt
    receivers = reclist
    exceptions
    too_many_receivers = 1
    document_not_sent = 2
    operation_no_authorization = 4
    others = 99.
    if sy-subrc <> 0.
    message id sy-msgid type sy-msgty number sy-msgno
    with sy-msgv1 sy-msgv2 sy-msgv3 sy-msgv4.
    endif.
    el error que tira es en la tranformacion a pdf dentro de la funcion
  • mysmb2
    • 406
    ¿podrías decirnos que dump te tira?
    Sebastián Chiavia
    • Hasurac
      • 41
      si es este
      Err.tmpo.ejec. CONVT_NO_NUMBER
      Fecha y hora 21.12.2009 16:12:00
      Texto breve
      Unable to interpret "*401" as a number.
      ¿Qué ha sucedido?
      Error in the ABAP Application Program
      The current ABAP program "SAPLSTXW" had to be terminated because it ha
      come across a statement that unfortunately cannot be executed.
      Anál.errores
      An exception occurred that is explained in detail below.
      This exception cannot be caught in the context of the current statemen
      The reason for the exception is:
      The program attempted to interpret the value "*401" as a number, but
      since the value contravenes the rules for correct number formats,
      this was not possible.
      Posición desencadenante de error tiempo ejecución
      Programa SAPLSTXW
      Include LSTXWU06
      Línea 114
      Tp.módulo (FUNCTION)
      Nombre módulo CONVERT_OTF
      Lín. Txt.fte.
      84 ************************************************** ***********
      85 * Adobe Acrobat PDF format
      86 ************************************************** ***********
      87 WHEN 'PDF'.
      88 BIN_FILESIZE = 0.
      89 if bin_file is supplied. "630
      90 pdf_destination = c_pdfcnv_pdfdst_xstring.
      91 clear bin_file.
      92 else.
      93 pdf_destination = c_pdfcnv_pdfdst_inttab.
      94 endif.
      95 perform pdfcnv_trace_otf tables otf.
      96 perform pdfcnv_convertotf tables otf
      97 lines
      98 using C_PDFCNV_OTFSRC_INTTAB
      99 archive_index
      100 copynumber
      101 spoolid
      102 pdf_destination
      103 dst_device
      104 dst_spoolid
      105 bin_filesize
      106 bin_file
      107 pdf_delete_otftab.
      108 subrc = sy-subrc.
      109 if pdf_delete_otftab = space.
      110 perform pdfcnv_save_otf_tospool tables otf
      111 using bin_filesize.
      112 endif.
      113 set locale language cur_system_lang.
      >>>>> IF BIN_FILESIZE < 0 or subrc <> 0.
      115 RAISE ERR_CONV_NOT_POSSIBLE. "unable to convert to PDF
      116 ENDIF.
      117 ************************************************** ***********
      118 * unsupported format
      119 ************************************************** ***********
      • Hasurac
        • 41
        ya solucione ese problema pero ahora cuando lo mando al mail lo recivo como pdf-2 el programa que uso para convertir es 'CONVERT_OTF_2_PDF' alguien me podria decir por que XD
        • quake1107
          Convt_no_number
          Hola HASURAC
          Disculpa cómo solucionaste lo del DUMP CONVT_NO NUMBER, tengo un problema similar,
          de antemano muchas Gracias!
