Err.tmpo.ejec. CONVT_CODEPAGEExcep. CX_SY_CONVERSION_CODEPAGE
Fecha y hora 15.01.2010 03:29:32
Texto breve
A character set conversion is not possible.
¿Qué ha sucedido?
At the conversion of a text from codepage '4102' to codepage '1100':
- a character was found that cannot be displayed in one of the two
codepages;
- or it was detected that this conversion is not supported
The running ABAP program 'ZPRO_004' had to be terminated as the conversion
would have produced incorrect data.
The number of characters that could not be displayed (and therefore not
be converted), is 1. If this number is 0, the second error case, as
mentioned above, has occurred.
¿Qué puede hacer?
Please make a note of the actions and input which caused the error.
To resolve the problem, contact your
SAP system administrator.
With transaction ST22 for the ABAP dump analysis, you can analyze and
administrate termination messages, or store them for a longer time
period.
If you were requested by the application to enter a codepage, the
termination may be avoided after the restart of the application if you
enter a different codepage.
If characters could not be converted: Please use transaction SCP to
analyse the codepages used by you. Search for characters you wanted to
convert, which are not entered in the table. (If you changed a codepage,
you can use transaction SP12 to invalidate the character set buffer
(CCC).
You find further help tools to codepages in transaction SNLS.
Anál.errores
An exception occurred that is explained in detail below.
The exception, which is assigned to class 'CX_SY_CONVERSION_CODEPAGE', was not
caught in
procedure "FILE_TABITE" "(FORM)", nor was it propagated by a RAISING clause.
Since the caller of the procedure could not have anticipated that the
exception would occur, the current program is terminated.
The reason for the exception is:
Characters are always displayed in only a certain codepage. Many
codepages only define a limited set of characters. If a text from a
codepage should be converted into another codepage, and if this text
contains characters that are not defined in one of the two codepages, a
conversion error occurs.
Moreover, a conversion error can occur if one of the needed codepages
'4102' or '1100' is not known to the system.
If the conversion error occurred at read or write of screen, the file
name was '/home/anonimo/CI_ITEMS'. (further information about the file: "X
405900 405900rw-rw-rw-201001140831002010011503293220100115032932")
Notas para corregir errores
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
"CONVT_CODEPAGE" "CX_SY_CONVERSION_CODEPAGE"
"ZPRO_004" or "ZPRO_004"
"FILE_TABITE"
If you cannot solve the problem yourself and want to send an error
notification to SAP, include the following information:
1. The description of the current problem (short dump)
To save the description, choose "System->List->Save->Local File
(Unconverted)".
2. Corresponding system log
Display the system log by calling transaction SM21.
Restrict the time interval to 10 minutes before and five minutes
after the short dump. Then choose "System->List->Save->Local File
(Unconverted)".
3. If the problem occurs in a problem of your own or a modified SAP
program: The source code of the program
In the editor, choose "Utilities->More
Utilities->Upload/Download->Download".
4. Details about the conditions under which the error occurred or which
actions and input led to the error.
The exception must either be prevented, caught within proedure
"FILE_TABITE" "(FORM)", or its possible occurrence must be declared in the
RAISING clause of the procedure.
To prevent the exception, note the following:
Propiedades fichero /home/anonimo/CI_ITEMS
Autorizaciones rw-rw-rw-
Modificado el 15.01.2010 03:29:32
Último acceso 14.01.2010 08:31:00
Última modif.status 15.01.2010 03:29:32
Tam. 405900 Byte
Posición actual 405900
Entorno sistema
SAP-Release 700
Application server... "servicio_1"
Network address...... "20.20.20.10"
Operating system..... "AIX"
Release.............. "5.3"
Hardware type........ "00C3948E4C00"
Character length.... 16 Bits
Pointer length....... 64 Bits
Work process number.. 45
Shortdump setting.... "full"
Database server... "iansamysap1_1"
Database type..... "ORACLE"
Database name..... "PRD"
Database user ID.. "SAPPRD"
Char.set.... "C"
SAP kernel....... 700
created (date)... "Nov 18 2008 21:27:59"
create on........ "AIX 2 5 005DD9CD4C00"
Database version. "OCI_102 (10.2.0.2.0) "
Patch level. 185
Patch text.. " "
Database............. "ORACLE 9.2.0.*.*, ORACLE 10.1.0.*.*, ORACLE 10.2.0.*.*"
SAP database version. 700
Operating system..... "AIX 1 5, AIX 2 5, AIX 3 5, AIX 1 6"
Memory consumption
Roll.... 16192
EM...... 75417264
Heap.... 0
Page.... 32768
MM Used. 63363128
MM Free. 3668840
Usuario y transacción
Client.............. 200
User................ "ADMIN"
Language key........ "S"
Transaction......... " "
Program............. "ZPRO_004"
Screen.............. "SAPMSSY0 1000"
Screen line......... 6
Info posición de cancelación
Termination occurred in the ABAP program "ZPRO_004" - in "FILE_TABITE".
The main program was "ZPRO_004 ".
In the source code you have the termination point in line 804
of the (Include) program "ZPRO_004".
The program "ZPRO_004" was started as a background job.
Job Name....... "ZPRO_004"
Job Initiator.. "ADMIN"
Job Number..... 03001401
The termination is caused because exception "CX_SY_CONVERSION_CODEPAGE"
occurred in
procedure "FILE_TABITE" "(FORM)", but it was neither handled locally nor
declared
in the RAISING clause of its signature.
The procedure is in program "ZPRO_004 "; its source code begins in line
801 of the (Include program "ZPRO_004 ".
Lín. Txt.fte.
774 * IF P_UNIX NE SPACE.
775 * TRANSFER TABFACP2 TO P_FACTU LENGTH 92.
776 * ENDIF.
777 * APPEND TABFACP2.
778 *ENDFORM. " FILE_TABFACP
779 *&---------------------------------------------------------------------*
780 *& Form FILE_TABFACI
781 *&---------------------------------------------------------------------*
782 *FORM FILE_TABFACI.
783 * TABFACI-FIN = '|'.
784 * IF P_UNIX NE SPACE.
785 * TRANSFER TABFACI TO P_FACTU LENGTH 92.
786 * ENDIF.
787 * APPEND TABFACI.
788 *ENDFORM. " FILE_TABFACI
789 *&---------------------------------------------------------------------*
790 *& Form FILE_TABPED
791 *&---------------------------------------------------------------------*
792 FORM FILE_TABPED.
793 IF P_UNIX NE SPACE.
794 TRANSFER TABPED TO P_PEDID LENGTH 39.
795 ENDIF.
796 APPEND TABPED.
797 ENDFORM. " FILE_TABPED
798 *&---------------------------------------------------------------------*
799 *& Form FILE_TABITE
800 *&---------------------------------------------------------------------*
801 FORM FILE_TABITE.
802 IF P_UNIX NE SPACE.
803
>>>>> TRANSFER TABITE TO P_ITEMS LENGTH 197.
805 ENDIF.
806 APPEND TABITE.
807 ENDFORM. " FILE_TABITE
808 *&---------------------------------------------------------------------*
809 *& Form FILE_TABPLA
810 *&---------------------------------------------------------------------*
811 FORM FILE_TABPLA.
812 IF P_UNIX NE SPACE.
813 TRANSFER TABPLA TO P_PLANE LENGTH 53.
814 ENDIF.
815 APPEND TABPLA.
816 ENDFORM. " FILE_TABPLA
817 *&---------------------------------------------------------------------*
818 *& Form FILE_TABHIS
819 *&---------------------------------------------------------------------*
820 FORM FILE_TABHIS.
821 IF P_UNIX NE SPACE.
822 TRANSFER TABHIS TO P_HISTO LENGTH 66.
823 ENDIF.
Contenido campos sistema
Nom. Val.
SY-SUBRC 0
SY-INDEX 0
SY-TABIX 1110
SY-DBCNT 7
SY-FDPOS 0
SY-LSIND 0
SY-PAGNO 0
SY-LINNO 1
SY-COLNO 1
SY-PFKEY
SY-UCOMM
SY-TITLE Interfaz de Pago proveedores
SY-MSGTY I
SY-MSGID SF
SY-MSGNO 616
SY-MSGV1 ZPRO_004
SY-MSGV2 RE
SY-MSGV3 ES
SY-MSGV4
SY-MODNO 0
SY-DATUM 20100115
SY-UZEIT 030017
SY-XPROG SAPLSYST
SY-XFORM SYSTEM_HOOK_OPEN_DATASET
Llamadas/Eventos activos
Nº Cl. Programa Include Lín.
Nom.
3 FORM ZPRO_004 ZPRO_004 804
FILE_TABITE
2 FORM ZPRO_004 ZPRO_004 597
CARGA_PEDIDOS
1 EVENT ZPRO_004 ZPRO_004 339
START-OF-SELECTION
Nom.
Val.
Nº 3 Cl. FORM
Nom. FILE_TABITE
P_UNIX
0
5
8
SYST-REPID
ZPRO_004
0000000000000000000000000000000000000000
5554533322222222222222222222222222222222
A02FF00400000000000000000000000000000000
P_ITEMS
0000000000000000000000000000000000000000000000000
2666626666666244545445222222222222222222222222222
F8FD5F1EFE9DFF39F945D3000000000000000000000000000
TABITE
450052806600010 I28250000183 SELLO½MECANICO½SI 2000 ½430½½D 1½¾”½½½½½02049001GR 28 201
00000000000000000000000000000000000000000000000000 00000000000000000020000000000000000000000000
00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000
333333333333333243333333333322222254444B44444444B5 4233332B333BB423BB1BBBBB33333333452332222333
450052806600010092825000018300000035CCFDD531E93FD3 9020000D430DD401DEDDDDDD02049001720280000201
