Err.tmpo.ejec. TIME_OUT
Fecha y hora 15.01.2010 15:22:00
Texto breve
Time limit exceeded.
¿Qué ha sucedido?
The program "ZPRO_004" has exceeded the maximum permitted runtime without
interruption and has therefore been terminated.
¿Qué puede hacer?
Note down which actions and inputs caused the error.
To process the problem further, contact you SAP system
administrator.
Using Transaction ST22 for ABAP Dump Analysis, you can look
at and manage termination messages, and you can also
keep them for a long time.
Anál.errores
After a specific time, the program is terminated to make the work area
available to other users who may be waiting.
This is to prevent a work area being blocked unnecessarily long by, for
example:
- Endless loops (DO, WHILE, ...),
- Database accesses with a large result set
- Database accesses without a suitable index (full table scan)
The maximum runtime of a program is limited by the system profile
parameter "rdisp/max_wprun_time". The current setting is 3000 seconds. If this
time limit is
exceeded, the system attempts to cancel any running SQL statement or
signals the ABAP processor to stop the running program. Then the system
waits another 60 seconds maximum. If the program is then still active,
the work process is restarted.
Notas para corregir errores
Programs with long runtime should generally be started as background
jobs. If this is not possible, you can increase the system profile
Depending on the cause of the error, you may have to take one of the
following measures:
- Endless loop: Correct program;
- Dataset resulting from database access is too large:
Instead of "SELECT * ... ENDSELECT", use "SELECT * INTO internal table
(for example);
- Database has unsuitable index: Check index generation.
If the error occures in a non-modified SAP program, you may be able to
find an interim solution in an SAP Note.
If you have access to SAP Notes, carry out a search with the following
keywords:
"TIME_OUT" " "
"ZPRO_004" or "ZPRO_004"
"CARGA_PROVEEDORES"
If you cannot solve the problem yourself and want to send an error
notification to SAP, include the following information:
1. The description of the current problem (short dump)
To save the description, choose "System->List->Save->Local File
(Unconverted)".
2. Corresponding system log
Display the system log by calling transaction SM21.
Restrict the time interval to 10 minutes before and five minutes
after the short dump. Then choose "System->List->Save->Local File
(Unconverted)".
3. If the problem occurs in a problem of your own or a modified SAP
program: The source code of the program
In the editor, choose "Utilities->More
Utilities->Upload/Download->Download".
4. Details about the conditions under which the error occurred or which
actions and input led to the error.
Info posición de cancelación
Termination occurred in the ABAP program "ZPRO_004" - in "CARGA_PROVEEDORES".
The main program was "ZPRO_004 ".
In the source code you have the termination point in line 987
of the (Include) program "ZPRO_004".
957 * --> p1 text
958 * <-- p2 text
959 *----------------------------------------------------------------------*
960 FORM CARGA_PROVEEDORES.
961 *-----------------------------------------------------------------
962 * PROCESO DE OBTENCION DE LA INFORMACION DESDE LA BASE DE DATOS
963 *-----------------------------------------------------------------
964 * Captura de los proveedores :
965 *----------------------------------
966 DATA HAY_COMPRAS.
967 REFRESH S_EKORG.
968 SELECT * FROM T024E WHERE BUKRS IN S_BUKRS.
969 CLEAR S_EKORG.
970 S_EKORG-SIGN = 'I'.
971 S_EKORG-OPTION = 'EQ'.
972 S_EKORG-LOW = T024E-EKORG.
973 APPEND S_EKORG.
974 ENDSELECT.
975
976
977
978
979 SELECT * FROM LFA1 WHERE LIFNR IN S_LIFNR.
980 * AND bukrs IN s_bukrs ORDER BY lifnr.
981 * ON CHANGE OF lfb1-lifnr.
982 SELECT * FROM LFB1 WHERE LIFNR = LFA1-LIFNR
983 AND BUKRS IN S_BUKRS.
984 * check sy-subrc EQ 0.
985 CLEAR HAY_COMPRAS .
986 SELECT * FROM T024E WHERE BUKRS EQ LFB1-BUKRS.
>>> SELECT * FROM LFM1 WHERE LIFNR EQ LFB1-LIFNR
988 AND EKORG EQ T024E-EKORG.989
990
991 CLEAR TABPRO.
992 HAY_COMPRAS = 'X'.
993 *tabpro-banks = ' '. tabpro-bankl = ' '. tabpro-bankn = ' '.
994 SELECT * FROM LFBK WHERE LIFNR = LFM1-LIFNR.
995
996 MOVE-CORRESPONDING LFBK TO TABPRO.
997
998 ENDSELECT.
999
000 MOVE-CORRESPONDING LFM1 TO TABPRO.
001 MOVE-CORRESPONDING LFA1 TO TABPRO.
002 MOVE-CORRESPONDING LFB1 TO TABPRO.
003
004 MOVE TABPRO-NAME1 TO I_TEXTO_DEPURADO.
005 PERFORM DEPURA_TEXTO.
006 MOVE I_TEXTO_DEPURADO TO TABPRO-NAME1.
Texto breve
¿Qué ha sucedido?
¿Qué puede hacer?
administrator.
Anál.errores
example:
time limit is
following measures:
(for example);
keywords:
"TIME_OUT" " "
"CARGA_PROVEEDORES"
(Unconverted)".
(Unconverted)".
957 * --> p1 text
958 * <-- p2 text
969 CLEAR S_EKORG.
973 APPEND S_EKORG.
974 ENDSELECT.
975
976
977
978
990
991 CLEAR TABPRO.
995
997
998 ENDSELECT.
999
003
