Ftp
  • DCErick
    • 1090
    Ftp
    Hola alguien sabra que funciones existen para trabajar con FTP, lo que necesito es conectarme a un sitio FTP, subir un archivo que el BANCO me dejara ahi y luego borrarlo.
    Pero no tengo idea de como hacerlo.....
  • andyoscky
    Miembro Honorario
    • 73
    Ejemplo
    estructura zx
    MANDT MANDT CLNT 3 0 Mandante
    SOURCE LOCALFILE CHAR 128 0 Fichero local para upload/download
    DESTINATION LOCALFILE CHAR 128 0 Fichero local para upload/download
    FILENAME LOCALFILE CHAR 128 0 Fichero local para upload/download
    ________________ ______________________________ __________ ______ ______ __________________________________________________ __________
    *"*"Interfase local
    *" IMPORTING
    *" REFERENCE(HOST) TYPE C
    *" REFERENCE(USERID) TYPE C
    *" REFERENCE(PASSWORD) TYPE C
    *" REFERENCE(USAGE) TYPE C
    *" REFERENCE(RFC_DESTINATION) LIKE RFCDES-RFCDEST
    *" TABLES
    *" COMMANDS
    *" RESULTS
    *" FILES STRUCTURE Zx
    *" EXCEPTIONS
    *" INVALID_USAGE
    *" NO_FILES_TO_TRANSFER
    *" NO_FTP_COMMANDS_TO_EXECUTE
    *" FTP_CONNECTION_FAILED
    *" FTP_COMMAND_FAILURE
    *Function Z_x
    *Purpose: This function module simplifies implementation of FTP
    *functionality by reducing the setup required and number of calls
    *involved within ABAP. This function can operate by passing a table of
    *files with source and destination locations to be transferred or by
    *passing a table of FTP commands to be executed.
    *Parameter Description:
    *HOST The host address of the FTP server. Usually specified as
    *an IP address. (ex. 65.212.34.120)
    *USERID The userid used to login to the FTP server
    *PASSWORD The password used to login to the FTP server. Unlike the
    *manual implementation of FTP this function accepts only
    *plain text passwords.
    *USAGE Determines the mode of operation for ZEASY_FTP. Valid
    *values are ‘S’, ‘R’, or ‘A’.
    *‘S’end – When using mode ‘S’ a table of filenames (FILES)
    *with the corresponding source and destination locations are passed in.
    *The function will send all files from their source locations to the
    *destination locations on the FTP server.
    *‘R’etrieve – When using mode ‘R’ a table of filenames (FILES) with the
    *corresponding source and destination locations are passed in. The
    *function will retrieve all files from the source locations on the FTP
    *server and place them in the appropriate destination locations.
    *‘A’dvanced – When using mode ‘A’ a table of commands (COMMANDS) is
    *passed in. These commands are executed in sequential order.
    *RFC_DESTINATION Determines which ‘local’ view to use during the
    *transfer process. Valid values are ‘SAPFTP’ or
    *‘SAPFTPA’. These destinations are configured in SM59 and already exist
    *as defaults provided by SAP.
    *‘SAPFTP’ – Use this value to transfer files between
    *the GUI front-end machine and the FTP server.
    *‘SAPFTPA’ – Use this value to transfer files between the SAP
    *application server and the FTP server.
    *Table Description:
    *COMMANDS Table of FTP commands for processing. When using modes ‘S’ or
    *‘R’ this table will be filled on successful execution of ZEASY_FTP
    * with* the FTP commands used to perform the file transfer. When using
    *mode ‘A’ this table must be filled by the calling program with valid
    *FTP commands to be executed by ZEASY_FTP.
    *RESULTS Table containing a log of the FTP session results.
    *FILES Table containing the source location, destination location,
    *and filename of each file to be transferred. When using
    *modes ‘S’ or ‘R’ this table must be filled by the calling program.
    *The structure of the FILES table consists of the following:
    *SOURCE LIKE LOCALFILE (RLGRAP-FILENAME)
    *DESTINATION LIKE LOCALFILE (RLGRAP-FILENAME)
    *FILENAME LIKE LOCALFILE (RLGRAP-FILENAME)
    *Exception Description:
    *INVALID_USAGE The usage specified was not equal to a valid value
    *consisting of ‘S’, ‘R’, or ‘A’.
    *NO_FILES_TO_TRANSFER Mode ‘S’ or ‘R’ was specified for usage; however,
    *the necessary table of FILES was not specified.
    *NO_FTP_COMMANDS_TO_EXECUTE Mode ‘A’ was specified for usage;
    *however, the necessary table of COMMANDS
    *to be executed was not specified.
    *FTP_CONNECTION_FAILED There was a problem establishing the FTP
    *connection. Please verify the host
    *address, userid, and password of the FTP
    *server. Also verify that the correct
    *RFC_DESTINATION was specified.
    *FTP_COMMAND_FAILURE There was a problem executing the FTP
    *commands. Please check commands for
    *validity.
    *DOCUMENTATION/NOTES
    * Date: 05/2003
    * USAGE = 'S'end, 'R'etrieve, 'A'dvanced
    * RFC_DESTINATION = 'SAPFTP', 'SAPFTPA' - defined in SM59
    * Be aware that FTP userid's, passwords, and commands are case
    * sensitive! For easiest use please make sure that the FTP account has
    * been created with a lowercase userid and password and TRANSLATE
    * the userid and password parameters to lower case before calling this
    * function.
    * Cannot test ZEASY_FTP, FTP_CONNECT, or other functions that use
    * FTP_CONNECT from function tester (auto converts test data to upper
    * case)!
    * Parameters on selection screens are auto converted to upper case
    * during AT SELECTION-SCREEN.
    * Structure of ZEASYFTP_FILES (FILES table)
    * SOURCE LIKE LOCALFILE
    * DESTINATION LIKE LOCALFILE
    * FILENAME LIKE LOCALFILE
    data: l_key type i value 26101957.
    data: l_length type i.
    data: l_lines type i.
    data: l_ftp_handle type i.
    data: l_cd_src(3) type c.
    data: l_cd_dest(3) type c.
    data: l_transfer_command(3) type c.
    *ENSURE PROPER EXECUTION *
    if usage ne 'S' and usage ne 'R' and usage ne 'A'.
    raise invalid_usage.
    endif.
    case usage.
    when 'A'.
    describe table commands lines l_lines.
    if l_lines = 0.
    raise no_ftp_commands_to_execute.
    endif.
    when 'S' or 'R'.
    clear: commands. refresh: commands.
    describe table files lines l_lines.
    if l_lines = 0.
    raise no_files_to_transfer.
    endif.
    * build commands
    if usage = 'S'.
    l_cd_src = 'lcd'.
    l_cd_dest = 'cd'.
    l_transfer_command = 'put'.
    elseif usage = 'R'.
    l_cd_src = 'cd'.
    l_cd_dest = 'lcd'.
    l_transfer_command = 'get'.
    endif.
    sort files by source destination.
    loop at files.
    at new source.
    if not files-source is initial.
    concatenate l_cd_src files-source into commands
    separated by space.
    append commands.
    endif.
    endat.
    at new destination.
    if not files-destination is initial.
    concatenate l_cd_dest files-destination into commands
    separated by space.
    append commands.
    endif.
    endat.
    if not files-filename is initial.
    concatenate l_transfer_command files-filename into commands
    separated by space.
    append commands.
    endif.
    endloop.
    endcase.
    *ENCRYPT PASSWORD *
    l_length = strlen( password ).
    call 'AB_RFC_X_SCRAMBLE_STRING'
    id 'SOURCE' field password id 'KEY' field l_key
    id 'SCR' field 'X' id 'DESTINATION' field password
    id 'DSTLEN' field l_length.
    *ESTABLISH FTP CONNECTION *
    call function 'FTP_CONNECT'
    exporting
    user = userid
    password = password
    host = host
    rfc_destination = rfc_destination
    importing
    handle = l_ftp_handle
    exceptions
    not_connected = 1
    others = 2.
    if sy-subrc <> 0.
    raise ftp_connection_failed.
    endif.
    *PROCESS FTP COMMANDS *
    call function 'FTP_COMMAND_LIST'
    exporting
    tables
    data = results
    commands = commands
    exceptions
    tcpip_error = 1
    command_error = 2
    data_error = 3
    others = 4.
    if sy-subrc <> 0.
    raise ftp_command_failure.
    endif.
    *CLOSE FTP CONNECTION *
    call function 'FTP_DISCONNECT'
    exporting
    handle = l_ftp_handle.
    endfunction.
