Como crear un mensaje de error en Web Dynpro
  • Jacobo
    • 58
    Quería saber como crear un mensaje de error en Web Dynpro para sacarlo por pantalla cuando se ha escrito algo incorrecto o se deja el campo vacio,que pasos habría que hacer,soy nuevo en esto del Webdynpro y la parte de los mensajes nunca la he visto
  • sook
    • 16
    Que tal Jacobo.
    Te pongo una parte de código para que lo hagas similar
    DATA: lo_message_manager TYPE REF TO if_wd_message_manager.
    lo_message_manager->report_error_message(
    message_text = 'Este es mi mensaje de error' ).
    EXIT.
    • Jacobo
      • 58
      al poner ese código me da un dump
      Hola Sook,no me va,te pongo lo que me sale,como puedo corregirlo
      What has happened?
      The URL http://agrupo2.dnsalias.com:8000/sap..._wd_reservas2/ was not called due to an error.
      Note
      ■The following error text was processed in the system IDE : Access via 'NULL' object reference not possible.
      ■The error occurred on the application server idesecc_IDE_00 and in the work process 0 .
      ■The termination type was: RABAX_STATE
      ■The ABAP call stack was:
      Method: ONACTIONBUSCARR of program /1BCWDY/B0TA3C3U8UXMLH61OW99==CP
      Method: IF_WDR_VIEW_DELEGATE~WD_INVOKE_EVENT_HANDLER of program /1BCWDY/B0TA3C3U8UXMLH61OW99==CP
      Method: INVOKE_EVENTHANDLER of program CL_WDR_DELEGATING_VIEW========CP
      Method: IF_WDR_ACTION~FIRE of program CL_WDR_ACTION=================CP
      Method: DO_HANDLE_ACTION_EVENT of program CL_WDR_WINDOW_PHASE_MODEL=====CP
      Method: PROCESS_REQUEST of program CL_WDR_WINDOW_PHASE_MODEL=====CP
      Method: PROCESS_REQUEST of program CL_WDR_WINDOW=================CP
      Method: EXECUTE of program CL_WDR_MAIN_TASK==============CP
      Method: IF_HTTP_EXTENSION~HANDLE_REQUEST of program CL_WDR_MAIN_TASK==============CP
      Method: EXECUTE_REQUEST_FROM_MEMORY of program CL_HTTP_SERVER================CP
      What can I do?
      ■If the termination type was RABAX_STATE, then you can find more information on the cause of the termination in the system IDE in transaction ST22.
      ■If the termination type was ABORT_MESSAGE_STATE, then you can find more information on the cause of the termination on the application server idesecc_IDE_00 in transaction SM21.
      ■If the termination type was ERROR_MESSAGE_STATE, then you can search for more information in the trace file for the work process 0 in transaction ST11 on the application server idesecc_IDE_00 . In some situations, you may also need to analyze the trace files of other work processes.
      ■If you do not yet have a user ID, contact your system administrator.
      Error code: ICF-IE-http -c: 800 -u: MASTER203 -l: E -s: IDE -i: idesecc_IDE_00 -w: 0 -d: 20110810 -t: 230456 -v: RABAX_STATE -e: OBJECTS_OBJREF_NOT_ASSIGNED_NO
      HTTP 500 - Internal Server Error
      Your SAP Internet Communication Framework Team
      • sook
        • 16
        Perdón, es q me faltó poner el código de creación de éstos objetos.
        Sería algo así:
        Data:
        lo_comp TYPE REF TO if_wd_component,
        lo_comp = wd_comp_controller->wd_get_api( ). lo_message_manager = lo_comp->get_message_manager( ).
        message_text = 'tu error' ).
        EXIT.
        Con eso debería de funcionar.
        • Jacobo
          • 58
          Gracias,si ya me va ,saludos
