Hola, buenos dias, cuando ejecuto el reporte alv tree que acabo de crear me da este error: GETWA_NOT_ASSIGNED
ya revise todos los field symbol y todos los desasigno, reviso y reviso el codigo y no encuentro el error.
Cσdigo:
*& Report ZFI_RECONCILIATION_REPORT_R
*& ABAPER: Javier Portilla
*& DATE: 11/22/2011
REPORT ZFI_RECONCILIATION_REPORT_R.
TABLES: makt, mseg, ekbe, ekpo, s012.
* DECLARACION DE TYPES *
TYPES: BEGIN OF TY_SPFLI,
matnr TYPE ekbe-matnr,
ebeln TYPE ekbe-ebeln,
belnr TYPE ekbe-belnr,
menge TYPE ekbe-menge,
dmbtr TYPE ekbe-dmbtr,
bwart TYPE ekbe-bwart,
budat TYPE ekbe-budat,
END OF TY_SPFLI.
TYPES: BEGIN OF TY_HEADER,
matnr TYPE makt-matnr,
maktx TYPE makt-maktx,
netwr TYPE s012-netwr,
wewrt_b TYPE s012-wewrt_b,
rewrt TYPE s012-rewrt,
END OF TY_HEADER.
* DECLARACION DE TABLAS INTERNAS *
DATA: T_SPFLI TYPE STANDARD TABLE OF TY_SPFLI
WITH HEADER LINE,
TAB_TREE TYPE STANDARD TABLE OF TY_SPFLI
WITH HEADER LINE,
T_TREE TYPE STANDARD TABLE OF TY_SPFLI
WITH HEADER LINE,
T_HEADER TYPE STANDARD TABLE OF TY_HEADER
WITH HEADER LINE.
* DECLARACION DE VARIABLES *
DATA: G_ALV_TREE TYPE REF TO CL_GUI_ALV_TREE,
L_HIERARCHY_HEADER TYPE TREEV_HHDR,
GS_FIELDCAT TYPE LVC_S_FCAT,
GT_FIELDCAT_TREE TYPE LVC_T_FCAT,
G_CUSTOM_CONTAINER TYPE REF TO CL_GUI_CUSTOM_CONTAINER.
* DECLARACION DE FIELD-SYMBOLS *
FIELD-SYMBOLS: <HEADER> LIKE LINE OF T_HEADER,
<SPFLI> LIKE LINE OF T_SPFLI.
* SELECTION-SCREEN *
SELECTION-SCREEN BEGIN OF BLOCK b1 WITH FRAME TITLE text-001.
SELECT-OPTIONS: Material FOR makt-matnr,
Purchase FOR s012-ekorg.
SELECTION-SCREEN END OF BLOCK b1.
* START-OF-SELECTION *
START-OF-SELECTION.
PERFORM OBTENER_DATOS.
IF G_ALV_TREE IS INITIAL.
PERFORM INIT_TREE.
CALL METHOD CL_GUI_CFW=>FLUSH
EXCEPTIONS CNTL_SYSTEM_ERROR = 1
CNTL_ERROR = 2.
CALL SCREEN 100.
* FORM init_tree *
FORM INIT_TREE.
DATA: L_TREE_CONTAINER_NAME(30) TYPE C.
L_TREE_CONTAINER_NAME = 'TREE_CONTROL'.
CREATE OBJECT G_CUSTOM_CONTAINER
CONTAINER_NAME = L_TREE_CONTAINER_NAME
EXCEPTIONS
CNTL_ERROR = 1
CNTL_SYSTEM_ERROR = 2
CREATE_ERROR = 3
LIFETIME_ERROR = 4
LIFETIME_DYNPRO_DYNPRO_LINK = 5.
CREATE OBJECT G_ALV_TREE
PARENT = G_CUSTOM_CONTAINER
NODE_SELECTION_MODE = CL_GUI_COLUMN_TREE=>NODE_SEL_MODE_SINGLE
ITEM_SELECTION = ''
NO_HTML_HEADER = 'X'
NO_TOOLBAR = ''
EXCEPTIONS
CNTL_ERROR = 1
CREATE_ERROR = 3
LIFETIME_ERROR = 4
ILLEGAL_NODE_SELECTION_MODE = 5
FAILED = 6
ILLEGAL_COLUMN_NAME = 7.
PERFORM FILL_CATALOG_TREE.
PERFORM BUILD_HIERARCHY_HEADER CHANGING L_HIERARCHY_HEADER.
CALL METHOD G_ALV_TREE->SET_TABLE_FOR_FIRST_DISPLAY
IS_HIERARCHY_HEADER = L_HIERARCHY_HEADER
CHANGING
IT_OUTTAB = T_TREE[]
IT_FIELDCATALOG = GT_FIELDCAT_TREE.
PERFORM CREATE_HIERARCHY.
ENDFORM.
* FORM FILL_CATALOG_TREE *
DATA: GS_FIELDCAT_ADD TYPE LVC_S_FCAT.
CLEAR GS_FIELDCAT.
GS_FIELDCAT-COL_POS = 1.
GS_FIELDCAT-REPTEXT = 'Material'.
GS_FIELDCAT-SCRTEXT_S = 'Material'.
GS_FIELDCAT-FIELDNAME = 'MATNR'.
GS_FIELDCAT-TABNAME = 'T_SPFLI'.
APPEND GS_FIELDCAT TO GT_FIELDCAT_TREE.
CLEAR GS_FIELDCAT.
GS_FIELDCAT-COL_POS = 2.
GS_FIELDCAT-REPTEXT = 'PO'.
GS_FIELDCAT-SCRTEXT_S = 'PO'.
GS_FIELDCAT-FIELDNAME = 'EBELNS'.
CLEAR GS_FIELDCAT.
GS_FIELDCAT-COL_POS = 3.
GS_FIELDCAT-REPTEXT = 'FI DOC'.
GS_FIELDCAT-SCRTEXT_S = 'FI DOC'.
GS_FIELDCAT-FIELDNAME = 'BELNR'.
GS_FIELDCAT-OUTPUTLEN = '15'.
CLEAR GS_FIELDCAT.
GS_FIELDCAT-COL_POS = 4.
GS_FIELDCAT-REPTEXT = 'MENGE'.
GS_FIELDCAT-SCRTEXT_S = 'MENGE'.
GS_FIELDCAT-FIELDNAME = 'QTY'.
GS_FIELDCAT-OUTPUTLEN = '20'.
CLEAR GS_FIELDCAT.
GS_FIELDCAT-COL_POS = 5.
GS_FIELDCAT-REPTEXT = 'AMOUNT'.
GS_FIELDCAT-SCRTEXT_S = 'AMOUNT'.
GS_FIELDCAT-FIELDNAME = 'DMBTR'.
CLEAR GS_FIELDCAT.
GS_FIELDCAT-COL_POS = 6.
GS_FIELDCAT-REPTEXT = 'DATE'.
GS_FIELDCAT-SCRTEXT_S = 'DATE'.
GS_FIELDCAT-FIELDNAME = 'BUDAT'.
ENDFORM.
* FORM build_hierarchy_header *
P_HIERARCHY_HEADER TYPE TREEV_HHDR.
CLEAR P_HIERARCHY_HEADER.
P_HIERARCHY_HEADER-HEADING = 'Materials'(300).
P_HIERARCHY_HEADER-WIDTH = 18.
P_HIERARCHY_HEADER-WIDTH_PIX = ' '.
ENDFORM.
* FORM create_hierarchy *
DATA: L_ROOT_KEY TYPE LVC_NKEY,
L_NEXT_KEY TYPE LVC_NKEY,
L_LAST_KEY TYPE LVC_NKEY,
HEADER TYPE STRING,
W_MENGE_TEXT(13) TYPE C.
CLEAR L_ROOT_KEY.
LOOP AT T_HEADER ASSIGNING <HEADER>.
CLEAR L_ROOT_KEY.
CLEAR L_NEXT_KEY.
PERFORM ADD_NODE USING <HEADER>-MATNR L_ROOT_KEY
CHANGING L_NEXT_KEY.
LOOP AT T_SPFLI ASSIGNING <SPFLI>
WHERE MATNR EQ <HEADER>-MATNR.
MOVE-CORRESPONDING <SPFLI> TO TAB_TREE.
PERFORM ADD_LEAF USING TAB_TREE L_NEXT_KEY
CHANGING L_LAST_KEY.
ENDLOOP.
ENDLOOP.
CALL METHOD G_ALV_TREE->FRONTEND_UPDATE.
ENDFORM.
* FORM ADD_NODE *
FORM ADD_NODE USING L_NAME L_ROOT_KEY
DATA: L_NODE_TEXT TYPE LVC_VALUE,
LS_TREE TYPE TY_SPFLI.
L_NODE_TEXT = L_NAME.
CALL METHOD G_ALV_TREE->ADD_NODE
I_RELAT_NODE_KEY = L_ROOT_KEY
I_RELATIONSHIP = CL_GUI_COLUMN_TREE=>RELAT_LAST_CHILD
I_NODE_TEXT = L_NODE_TEXT
IS_OUTTAB_LINE = LS_TREE
IMPORTING
E_NEW_NODE_KEY = L_NEXT_KEY.
ENDFORM.
* FORM ADD_LEAF *
FORM ADD_LEAF USING L_TREE TYPE TY_SPFLI
L_NEXT_KEY
I_RELAT_NODE_KEY = L_NEXT_KEY
IS_OUTTAB_LINE = TAB_TREE
IMPORTING
E_NEW_NODE_KEY = L_LAST_KEY.
ENDFORM.
* FORM OBTENER_DATOS *
FORM OBTENER_DATOS.
* SELECT CARRID CONNID COUNTRYFR CITYFROM
* AIRPFROM COUNTRYTO CITYTO
* INTO TABLE T_SPFLI
* FROM SPFLI.
SELECT matnr
ebeln
belnr
menge
dmbtr
bwart
budat
INTO TABLE T_SPFLI
FROM ekbe
WHERE ekbe~bwart IN ('101', '102')
AND ekbe~matnr NE ''.
IF SY-SUBRC EQ 0.
LOOP AT T_SPFLI ASSIGNING <SPFLI>.
MOVE <SPFLI>-MATNR TO T_HEADER-MATNR.
APPEND T_HEADER.
ENDLOOP.
SORT T_HEADER.
DELETE ADJACENT DUPLICATES FROM T_HEADER.
ENDFORM.
