ALV TREE problema para obtener suma de columnas
  • javico40
    • 37
    Hola comunidad, modifique el fieldcatalog para poder obtener la sumatoria de las columnas pero no funciona, no me muestra ninguna suma cuando lo ejecuto y cuando apreto el boton de sumar del toolbar no hace nada, ayuda.
    Código:
    FORM FILL_CATALOG_TREE.
      DATA: GS_FIELDCAT_ADD TYPE LVC_S_FCAT.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 1.
      GS_FIELDCAT-REPTEXT   = 'DESC'.
      GS_FIELDCAT-SCRTEXT_S = 'DESC'.
      GS_FIELDCAT-COLTEXT = 'DESCRIPTION'.
      GS_FIELDCAT-FIELDNAME = 'MAKTX'.
      GS_FIELDCAT-TABNAME = 'T_SPFLI'.
      GS_FIELDCAT-OUTPUTLEN = '50'.
      APPEND GS_FIELDCAT TO GT_FIELDCAT_TREE.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 2.
      GS_FIELDCAT-COLTEXT = 'PO VALUE'.
      GS_FIELDCAT-REPTEXT   = 'PO VALUE'.
      GS_FIELDCAT-SCRTEXT_S = 'PO VALUE'.
      GS_FIELDCAT-FIELDNAME = 'NETWR'.
      GS_FIELDCAT-OUTPUTLEN = '40'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 3.
      GS_FIELDCAT-COLTEXT = 'ORDER QUANTITY'.
      GS_FIELDCAT-REPTEXT   = 'ORDER QTY'.
      GS_FIELDCAT-SCRTEXT_S = 'ORDER QTY'.
      GS_FIELDCAT-FIELDNAME = 'MENGE'.
      GS_FIELDCAT-OUTPUTLEN = '30'.
      GS_FIELDCAT-DO_SUM    = 'X'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 4.
      GS_FIELDCAT-REPTEXT   = 'MM DOC'.
      GS_FIELDCAT-SCRTEXT_S = 'MM DOC'.
      GS_FIELDCAT-FIELDNAME = 'MMDOC'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 5.
      GS_FIELDCAT-COLTEXT = 'GR QUANTITY'.
      GS_FIELDCAT-REPTEXT   = 'GR QUATY'.
      GS_FIELDCAT-SCRTEXT_S = 'GR QUATY'.
      GS_FIELDCAT-FIELDNAME = 'MENGE_MM'.
      GS_FIELDCAT-h_ftype = 'SUM'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 6.
      GS_FIELDCAT-COLTEXT = 'GR AMOUNT'.
      GS_FIELDCAT-REPTEXT   = 'GR AMOUNT'.
      GS_FIELDCAT-SCRTEXT_S = 'GR AMOUNT'.
      GS_FIELDCAT-FIELDNAME = 'DMBTR_MM'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 7.
      GS_FIELDCAT-REPTEXT   = 'FI DOC'.
      GS_FIELDCAT-SCRTEXT_S = 'FI DOC'.
      GS_FIELDCAT-FIELDNAME = 'FIDOC'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 8.
      GS_FIELDCAT-REPTEXT   = 'INVOICE QUATY'.
      GS_FIELDCAT-SCRTEXT_S = 'INVOICE QUATY'.
      GS_FIELDCAT-COLTEXT = 'INVOICE QUANTITY'.
      GS_FIELDCAT-FIELDNAME = 'MENGE_FI'.
      CLEAR GS_FIELDCAT.
      GS_FIELDCAT-COL_POS   = 9.
      GS_FIELDCAT-REPTEXT   = 'INVOICE AMOUNT'.
      GS_FIELDCAT-SCRTEXT_S = 'INVOICE AMOUNT'.
      GS_FIELDCAT-COLTEXT = 'INVOICE AMOUNT'.
      GS_FIELDCAT-FIELDNAME = 'DMBTR_FI'.
  • Ridder
    Did you get the solution?
    I'm facing the same problem... If you got a solution... could you share it? Pls...
    • sconoredhot
      • 341
      hola
      De que tipo de dato son los campos que queres sumar?
      Sebas
      Desarrollador ABAP.
