Dump con sentencia SUBMIT
  • cosagaucha
    • 64
    Hola a todos, estoy teniendo este problema, se genera un dump en esta sentencia:
    SUBMIT (p_name) VIA SELECTION-SCREEN AND RETURN.
    y lo unico "raro" de la misma, en todo caso, es el valor que llega ahi a p_name, que es '/1BCDWB/DBVBAK'.
    Esta correcto que sea asi ese literal? O el dump se debe a las / del contenido?
    Este es parte del dump:
    The current ABAP program "SAPLZBC004" had to be terminated because it has
    come across a statement that unfortunately cannot be executed.
    The following syntax error occurred in program "/1BCDWB/DBVBAK " in include
    line 1090:
    "Campo "%_ENQU_VBAK" desconocido: No está incluido en una de las tablas"
    " indicadas ni definido mediante una sentencia "DATA" ."
    The include has been created and last changed by:
    Created by: "SAP* "
    Last changed by: "SAP* "
    Error in the ABAP Application Program
    .errores
    The following syntax error was found in the program /1BCDWB/DBVBAK :
