enviar pdf por correo. no envia archivo adjunto
  • CESARCAES01
    • 46
    hola a todos tengo un problema con el archivo pdf para enviarlo por correo, aca dejo el codigo que estoy usando pero no encuentro donde enviar el archivo pdf.
    FORM USER_COMMAND USING R_UCOMM LIKE SY-UCOMM RS_SELFIELD TYPE SLIS_SELFIELD.
    *CASE rs_selfield-fieldname.
    READ TABLE gt_report INTO gs_report INDEX rs_selfield-tabindex.
    DATA: it_body TYPE TABLE OF solisti1 WITH HEADER LINE,
    gd_doc_data LIKE sodocchgi1,
    it_packing_list LIKE sopcklsti1 OCCURS 0 WITH HEADER LINE,
    it_receivers LIKE somlreci1 OCCURS 0 WITH HEADER LINE,
    tab_lines LIKE sy-tabix.
    DATA: wl_body LIKE it_body-line.
    * Armamos el contenido del cuerpo
    CONCATENATE text-m01 '904512' text-m02 'MMMTPA' '.'
    INTO wl_body SEPARATED BY space.
    it_body-line = wl_body.
    APPEND it_body.
    ** Equivalente a un salto de linea
    CLEAR wl_body.
    APPEND it_body.
    APPEND gs_report to li_dat_bin.
    ** Pie de Cuerpo
    it_body-line = text-m03.
    APPEND it_body.
    * Creamos el mail
    DESCRIBE TABLE it_body LINES tab_lines.
    READ TABLE it_body INDEX tab_lines.
    gd_doc_data-doc_size = ( tab_lines ) * 255 + STRLEN( it_body ).
    * atributos especiales del mensaje
    gd_doc_data-obj_langu = sy-langu.
    gd_doc_data-obj_descr = text-m04.
    * Cuerpo del mensaje
    it_packing_list-transf_bin = space.
    it_packing_list-head_start = 1.
    it_packing_list-head_num = 0.
    it_packing_list-body_start = 1.
    DESCRIBE TABLE it_body LINES it_packing_list-body_num.
    it_packing_list-doc_type = 'bin'.
    * it_packing_list-obj_name = gs_report-PAY_RECEIPT.
    it_packing_list-obj_name ='File'.
    APPEND it_packing_list.
    * add direc. mail
    it_receivers-receiver = 'cesarcaes01@gmail.com'.
    it_receivers-rec_type = 'U'.
    it_receivers-com_type = 'INT'.
    it_receivers-notif_del = 'X'.
    it_receivers-notif_ndel = 'X'.
    APPEND it_receivers.
    "SEND MAIL ALL Ó DOWNLOAD MAIL
    CASE R_UCOMM.
    "Send mail all employee
    WHEN '/&INFO'.
    WRITE :/02 SY-VLINE, rs_selfield-fieldname.
    write R_UCOMM.
    write rs_selfield-value.
    *CLEAR gt_report.
    * CHECK rs_selfield-tabindex NE 0.
    * READ TABLE gt_report INTO gs_report INDEX rs_selfield-tabindex.
    IF sy-subrc EQ 0.
    CALL FUNCTION 'SO_NEW_DOCUMENT_ATT_SEND_API1'
    document_data = gd_doc_data
    * put_in_outbox = 'X'
    commit_work = 'X'
    TABLES
    packing_list = it_packing_list
    contents_txt = it_body
    receivers = it_receivers
    EXCEPTIONS
    too_many_receivers = 1
    document_not_sent = 2
    document_type_not_exist = 3
    operation_no_authorization = 4
    parameter_error = 5
    x_error = 6
    enqueue_error = 7
    OTHERS = 8.
    IF sy-subrc EQ 0.
    WRITE: 'e-mail enviado exitósamente'.
    ELSE.
    WRITE: 'error en envió de e-mail'.
