Problema:DUMP al rellenar el catalogo de un alv grid.
  • Vero2007
    • 38
    Buenas, tengo UN problemas que igual me puedan ayudar a solucionar.
    Tengo un alv en una dynpro y me muestra bien la información de una tabla ,pasandole la estructura y los datos
    EL PROBLEMA viene cuando quiero que los campos tengan un determinado campo y texto para visualizar, porque tengo
    que rellenar un it_fieldcatalog (catalogo) para que tengas las características q quiero. En ese momento SAP me
    da un DUMP:
    Txt.brv.
    Field symbol has not yet been assigned.
    Anál.errores
    You attempted to access an unassigned field symbol
    (data segment 32821).
    This error may occur for any of the following reasons:
    - You address a typed field symbol before it is set using ASSIGN
    - You address a field symbol that points to a line in an internal table
    that has been deleted
    - You address a field symbol that had previously been reset using
    UNASSIGN, or that pointed to a local field that no longer exists
    - You address a global function interface parameter, even
    though the relevant function module is not active,
    that is it is not in the list of active calls. You can get the list
    of active calls from the this short dump.
    macro_cell_data_get
    <ls_fcat>
    <ls_data>
    <l_field_value>
    ls_lvc_data-value.
    > new API
    if ir_salv_adapter is bound.
    clear ls_lvc_data-style.
    Lo que yo tengo en el codigo es lo siguiente:
    * G L O B A L I N T E R N A L T A B L E S
    DATA: gi_zfitlogs TYPE TABLE OF zfitlogs.
    DATA: g_it_logs TYPE STANDARD TABLE OF zfitlogs WITH HEADER LINE.
    DATA: gi_fieldcat1 TYPE LVC_T_FCAT.
    *& Module STATUS_1500 OUTPUT
    * text
    MODULE STATUS_1500 OUTPUT.
    SET PF-STATUS 'MENU1500'.
    SET TITLEBAR 'TITULO1500'.
    * Crea los objetos
    IF go_custom_container IS INITIAL.
    CREATE OBJECT go_custom_container
    container_name = 'ALV_CONTAINER'.
    CREATE OBJECT go_grid
    i_parent = go_custom_container.
    ELSE.
    CALL METHOD go_grid->refresh_table_display.
    * Rellenar el catalogo
    PERFORM rellenar_catalogo1.
    * Rellenar el alv-grid
    PERFORM load_data_into_grid.
    ENDMODULE. " STATUS_1500 OUTPUT
    *& Form load_data_into_grid
    *& Con la tabla rellena de información para la alv, muestra una alv
    *& en una dynpro
    * Read data from table ZFITLOGS
    SELECT * FROM zfitlogs "client specified
    APPENDING TABLE gi_zfitlogs
    UP TO RSEUMOD-TBMAXSEL ROWS BYPASSING BUFFER
    WHERE zsior IN r_zsior
    AND ztpop IN r_ztpop
    AND zprog IN r_zprog
    AND zfent IN r_zfent
    AND zfpro IN r_zfpro
    AND zestl IN r_zestl
    AND usnam IN r_usnam.
    * Carga los datos en el grid y los muestra por pantalla
    CALL METHOD go_grid->set_table_for_first_display
    i_structure_name = 'ZFITLOGS'
    CHANGING
    it_outtab = gi_zfitlogs
    it_fieldcatalog = gi_fieldcat1.
    ENDFORM. " load_data_into_grid
    *& Form rellenar_catalogo1
    * text
    * --> p1 text
    * <-- p2 text
    FORM rellenar_catalogo1 .
    data: wa_fieldcat1 type lvc_s_fcat.
    " wa_fieldcat1-tabname = 'g_it_logs'.
    wa_fieldcat1-FIELDNAME = 'mandt'.
    wa_fieldcat1-SELTEXT = 'Mandante'.
    wa_fieldcat1-coltext = 'Columna Mandante'.
    " wa_fieldcat1-col_pos = 1.
    " wa_fieldcat1-outputlen = 20.
    append wa_fieldcat1 to gi_fieldcat1.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'znlog'.
    wa_fieldcat1-SELTEXT = 'Nombre del log'.
    wa_fieldcat1-coltext = 'Columna Nombre'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zprog'.
    wa_fieldcat1-SELTEXT = 'Nombre del programa'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zestl'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'usnam'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'znlar'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zncor'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zsior'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'ztpop'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zfent'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zfpro'.
    clear wa_fieldcat1.
    wa_fieldcat1-FIELDNAME = 'zhumd'.
    clear wa_fieldcat1.
    ENDFORM. " rellenar_catalogo2
    Necesitaria saber en que me estoy equivocando para que me dé ese DUMP porque ya he probado de todo,
    quitando unos campos poniendos otros, no poniendo el nombre del tabname,etc....
    Si alguien me puede ayudar se lo agradeceria.
    Un saludo, y gracias por adelantado.
  • ballan
    • 671
    Vero prueba a rellenar los campos REFTABLE y REFFIELD de la estructura wa_fieldcat1 con la tabla y el campo que has usado de referencia, p.e.
    data: begin of tabla occurs 0,
    campo1 like vbak-vbeln
    pues pon vbak en reftable y vbeln en reffield aver si asi te funciona
    un saludo
    • Vero2007
      • 38
      No va. Ya lo intenté y sigue saliendo ese error de :
      Txt.brv.
      No se a que se puede referir
      • ayasystems
        • 33
        Originalmente publicado por Vero2007
        CHANGING
        Hola Vero,
        ahora mismo no tengo sistema para poder verificarlo pero creo que si le pasas una tabla interna con el catalogo de campos no puedes especificarle la structura de referencia.
        Prueba a ver y dime.
        • Vero2007
          • 38
          Pos va a ser que da igual, porque ese error lo sigue dando.
          Yo solo quiero darle un tamaño a ciertos campos. Por un casual no habra otra forma de hacerlo que no sea por it_fieldcatalog?
          • ayasystems
            • 33
            Vero esta función "LVC_FIELDCATALOG_MERGE" te rellenará sola el catálogo.
            Prueba a pasarle el catálogo que te devuelve la función y ver si sigue dando el dump, así podemos determinar si es problema de los datos que van en el catálogo o que.
            ya lo he comprobado y si pasas el catálogo no puedes pasar la estructura de referencia.
            CALL FUNCTION 'LVC_FIELDCATALOG_MERGE'
            * I_BUFFER_ACTIVE =
            I_STRUCTURE_NAME = 'XXXXXXXXXX' (Tu tabla de BD)
            * I_CLIENT_NEVER_DISPLAY = 'X'
            * I_BYPASSING_BUFFER =
            CHANGING
            CT_FIELDCAT = IT_CATALOG[]
            EXCEPTIONS
            INCONSISTENT_INTERFACE = 1
            PROGRAM_ERROR = 2
            OTHERS = 3.
            Editado por última vez por ayasystems; 25/04/2007, 12:38:44.
            • Vero2007
              • 38
              Me funciona con "LVC_FIELDCATALOG_MERGE" , asiq así se queda. lo qeu tengo q conseguir ahora es modificar el campo outputlen para que me cambie el tamaño de lo que visualiza.
              La tabla interna gi_fieldcat1 que yo usaba por alguna razon no la acepta, incluso poniendole lo mismo que crea la tabla de la función asiq si con la funcion va pues asi se queda
              Muchas gracias
              Ahora voya intentar modificar ese campo concreto
              • ayasystems
                • 33
                Ok, me alegro de que lo hayas solucionado al final
                Ahora un lupete y a modificar valores, aunque yo miraría a ver por qué no pilla lo otro... soy muy cabezón con esas cosas
                • TonyTrex
                  Ese problema lo solucioné poniendo en mayúsculas el nombre del campo:
                  asi no----> wa_fieldcat1-FIELDNAME = 'znlog'
                  asi si ----> wa_fieldcat1-FIELDNAME = 'ZNLOG'
                  suerte!
                  • Vero2007
                    • 38
                    #10
                    Gracias porque si es eso, en todos los campos los tengo en minusculas y por ese pequeño detalle ya no me va.
                    Además el nombre de tabla q estaba usando estaba vacio y tenia otra tabla igual con datos, usaba la q no tenia datos.
                    Muchas gracias ya esta resuelto. CUIDADO CON LAS MAYUSCULAS para los que tengan el mismo fallo.
                    • ayasystems
                      • 33
                      #11
                      Yo soy de la opinion de que hay que hacer todo en mayúsculas pero cada uno que se apañe como pueda.... Los nombres de las funciones también son case sensitive... así que ojo con ellos
                      • BY_MY
                        • 130
                        #12
                        Buenas a todos.
                        Realmente hay que hacer todo con mayusculas, lo que pasa es que al compilar hay sitios donde el propio sap lo pasa a mayusculas (se puede usar el pretty printer para convertirlo y ver que esta bien todo y hasta donde compila) pero como en este caso, al ir entre comillas lo toma como un string y no convierte lo que hay dentro asi que siempre se deberia de poner en mayusculas a no ser que sea algo como un mensaje o algo similar que queramos en minusculas.
                        un saludo y aunque tarde espero que aporte algo para futuros problemas.
                        • ChristianS
                          #13
                          Originalmente publicado por TonyTrex
                          suerte!
                          Que tal?
                          Hoy pasé aprox 6 horas buscando por que me tiraba un DUMP " GETWA_NOT_ASSIGNED"... ya casi resignado vi este post salvador.
                          Creo que desde ahora voy a programar SOLO en mayusculas!
                          • ayasystems
                            • 33
                            #14
                            Originalmente publicado por ChristianS
                            Que tal?
                            Haces bien... mejor todo en mayúsculas
