2 ALV + 1 control text en Dynpro
  • JoNhNaTaN
    • 70
    Buenas tardes a todos, se ha requerido que en una pantalla haya 2 alv para visualizar documentos (cabecera y detalle de documentos), y tambien arriba del primer ALV haya un control box por el cual el usuario filtre los documentos respecto a un cliente. Ya tengo hecho los 2 alv (lo mas fálcil a mi parecer) pero no consigo poner el text control por encima del primer ALV. Adjunto el código de la construcción de los ALV.
    Código:
      CREATE OBJECT go_docking
          parent                      = cl_gui_container=>screen0
          ratio                       = 90
        EXCEPTIONS
          OTHERS                      = 6.
      IF sy-subrc  EQ 0.
    *   MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
    *              WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
      CREATE OBJECT go_splitter
          parent            = go_docking
          rows              = 2
          columns           = 1
        EXCEPTIONS
          cntl_error        = 1
          cntl_system_error = 2
          OTHERS            = 3.
      IF sy-subrc EQ 0.
      CALL METHOD go_splitter->get_container
          row       = 1
          column    = 1
        RECEIVING
          container = go_cell_top.
          row       = 2
          column    = 1
        RECEIVING
          container = go_cell_bottom.
    * Create ALV grids
      CREATE OBJECT go_grid1
          i_parent          = go_cell_top
        EXCEPTIONS
          OTHERS            = 5.
      IF sy-subrc EQ 0.
    * Set event handler
      SET HANDLER: lcl_eventhandler=>handle_double_click FOR go_grid1.
      CREATE OBJECT go_grid2
          i_parent          = go_cell_bottom
        EXCEPTIONS
          OTHERS            = 5.
      IF sy-subrc EQ 0.
      PERFORM excluir_botones.
      PERFORM fieldcat_top.
    * Display data
      CALL METHOD go_grid1->set_table_for_first_display
          i_structure_name = 'ZTBSD_CABECERA'
          is_layout        = gs_layout
          it_toolbar_excluding = gt_exclude
        CHANGING
          it_fieldcatalog      = gt_fieldcatalogTOP
          it_outtab        = gt_alumnos
        EXCEPTIONS
          OTHERS           = 4.
      IF sy-subrc EQ 0.
      PERFORM fieldcat_down.
      CALL METHOD go_grid2->set_table_for_first_display
          i_structure_name = 'ZTBST_DETALLE'
        CHANGING
          it_fieldcatalog      = gt_fieldcatalogDOWN
          it_outtab        = gt_out_down
        EXCEPTIONS
          OTHERS           = 4.
      IF sy-subrc EQ 0.
      CREATE OBJECT events.
        SET HANDLER events->handle_data_changed FOR go_grid2.
        SET HANDLER events->handle_data_changed_finished FOR go_grid2.
      CALL METHOD cl_gui_control=>set_focus
            control = go_grid2.
        CALL METHOD go_grid2->register_edit_event
            i_event_id = cl_gui_alv_grid=>mc_evt_enter.
            i_event_id = cl_gui_alv_grid=>mc_evt_modified.
        CALL METHOD go_grid2->refresh_table_display.
      CALL METHOD go_docking->link
          repid                       = syst-repid
          dynnr                       = '0100'
        EXCEPTIONS
          OTHERS                      = 4.
      IF sy-subrc EQ 0.
      CALL SCREEN '0100'.
    Cuando ejecuto el reporte se muestran los 2 alv uno debajo del otro, pero el text control se va a la parte derecha, la imagen la adjunto.
    Espero puedan ayudarme.
    Un abrazo a todos,
