error instalando Sap Netweaver 2004 ABAP trial
  • jpuigserverlara
    • 6
    Como dice una de las leyes de Murphy, "Cualquier solución entraña nuevos problemas".
    Me dispongo todo feliz a instalar mi flamante Sap Netweaver 2004 ABAP trial version, y después de haberlo intentado instalar 4 veces haciendo diferentes combinaciones, incluso formateando mi PC, siempre obtengo el siguiente error:
    (May 14, 2009 11:03:15 PM), Install, com.sap.installshield.maxdb.maxdb_call_sdbinst, err, An error occurred and product installation failed. Look at the log file C:\sapdb\NSP\log.txt for details.
    (May 14, 2009 11:03:15 PM), Install, com.sap.installshield.maxdb.maxdb_call_sdbinst, err, ProductException: (error code = 601; message="An Error happened during call of MaxDB Tool sdbinst. Check end of Logfile C:/DOCUME~1/jp/CONFIG~1/Temp/MaxDBSAPNWPREV.log")
    STACK_TRACE: 22
    at com.sap.installshield.maxdb.maxdb_call_sdbinst.ins tall(maxdb_call_sdbinst.java:193)
    at com.installshield.product.service.product.PureJava ProductServiceImpl.installProductAction(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.getResultForProd uctAction(Unknown Source)
    at com.installshield.product.service.product.Installa bleObjectVisitor.visitComponent(Unknown Source)
    at com.installshield.product.service.product.Installa bleObjectVisitor.visitInstallableComponents(Unknow n Source)
    at com.installshield.product.service.product.Installa bleObjectVisitor.visitProductBeans(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$InstallProduct.install(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl.installProduct(Unknown Source)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknow n Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.installshield.wizard.service.LocalImplementorP roxy.invoke(Unknown Source)
    at com.installshield.wizard.service.AbstractService.i nvokeImpl(Unknown Source)
    at com.installshield.product.service.product.GenericP roductService.installProduct(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl.installAssembly(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl.access$900(Unknown Source)
    at com.installshield.product.service.product.PureJava ProductServiceImpl$Installer.execute(Unknown Source)
    at com.installshield.wizard.service.AsynchronousOpera tion.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
    Tengo que decir que mi PC no cumple 2 de los requerimientos para la instalación:
    1) Solo tiene 512 MB de RAM y no 1GB como recomienda SAP.
    2) Tiene WIN XP HOME y no WIN XP PROFESSIONAL, pero creo haber leído por el foro que alguien lo ha instalado con el HOME sin problemas.
    Antes de que me corte las venas con un cutter oxidado, ¿Alguien me podría decir como se soluciona este error?
    Muchas gracias anticipadas,
    Joan
  • jpuigserverlara
    • 6
    Instalación con éxito de SAP NW2004S
    Hola a todos,
    Ya no hace falta que me corte las venas,
    Después de pasar el calvario de 7-8 intentos fallidos de instalar el NW2004S sobre XP HOME, decidí hacer caso a la recomendación de SAP de instalarlo sobre XP PROFESSIONAL (a pesar de que alguien me habia comentado de que lo habia instalado en el home sin problemas), y maravilla de las maravillas, se instaló correctamente a la primera y sin ningun error, esto sí, hace falta un 1gb de RAM de lo contrario te puedes morir de aburrimiento.
    Mas que nada contesto por si puedo evitar a alguién la tortura de las instalaciones fallidas,
    un saludo, Joan
    • tracer
      Administrator
      • 503
      Hola Joan,
      Hay un hilo abierto para esto en este post
      1ª Parte : Descargando e Instalando el SAP NetWeaver 2004s ABAP Trial Version (SP11)
      Un saludo
      Si precisas una mano, recuerda que yo tengo dos.
