Alguien m ayuda con un DUMP?
  • Driau
    • 235
    Hola a todos. He realizado un pequeño programa. Le he modificado un poco los botones del ALV para que cuando le doy a 'PROCESAR' me genere un fichero. Éste es el codigo:
    Código:
    REPORT ZDESNOTIFICAR.
    *  TAULES DE BASE DE DADES                                             *
    TABLES: AFRU.
    *  TYPES                                                               *
    *  TYPE-POOLS                                                          *
    TYPE-POOLS: SLIS.
    *  VARIABLES                                                           *
    DATA: V_LINES     TYPE I.
    DATA: G_REPID     LIKE SY-REPID.
    *VARIABLES ALV
    DATA: IT_FIELDCAT   TYPE SLIS_T_FIELDCAT_ALV.
    DATA: GS_LAYOUT     TYPE SLIS_LAYOUT_ALV.
    DATA: WA_FIELDCAT   TYPE LINE OF SLIS_T_FIELDCAT_ALV.
    *  TAULES INTERNES                                                     *
    DATA: BEGIN OF IT_AFRU OCCURS 0,
             AUFNR LIKE AFRU-AUFNR,
             RMZHL LIKE AFRU-RMZHL,
             LMNGA LIKE AFRU-LMNGA,
             MEINH LIKE AFRU-GMEIN,
    END OF IT_AFRU.
    DATA: BEGIN OF IT_OUT OCCURS 0,
             MEINH LIKE AFRU-MEINH,
    END OF IT_OUT.
    * PANTALLA DE SELECCIÓ                                                 *
    *INSERTAR NUMERO DE OF
    SELECTION-SCREEN BEGIN OF BLOCK b1 WITH FRAME TITLE TEXT-001.
    PARAMETERS:
    P_AUFNR LIKE AFRU-AUFNR.      "NÚMERO DE OF
    SELECTION-SCREEN END OF BLOCK b1.
    *  AT SELECTION-SCREEN                                                  *
    * PROGRAMA PRINCIPAL                                                    *
    START-OF-SELECTION.
      G_REPID = SY-REPID.
      SELECT AUFNR RMZHL LMNGA MEINH
        FROM AFRU
        INTO CORRESPONDING FIELDS OF TABLE IT_AFRU
        WHERE AUFNR = P_AUFNR.
      LOOP AT IT_AFRU.
        IT_AFRU-MEINH = 'UN'.
        APPEND IT_AFRU TO IT_OUT.
      ENDLOOP.
    *PREPARAMOS EL ALV-GRID
      DESCRIBE TABLE IT_OUT LINES V_LINES.
      CASE V_LINES.
        WHEN 0.
          MESSAGE TEXT-002 TYPE 'S'.
          EXIT.
        WHEN OTHERS.
          PERFORM CATALEG_ALV.
          PERFORM LAYOUT_ALV USING GS_LAYOUT.
          PERFORM MOSTRAR_ALV.
      ENDCASE.
    *  FORM: CATALEG_ALV                                                   *
    FORM CATALEG_ALV.
      CLEAR IT_FIELDCAT.
      CLEAR WA_FIELDCAT.
      	WA_FIELDCAT-FIELDNAME           = 'RMZHL'.
      	WA_FIELDCAT-SELTEXT_L           = 'Nº de Palet'.
      WA_FIELDCAT-OUTPUTLEN           = 10.
      APPEND WA_FIELDCAT TO IT_FIELDCAT.
      CLEAR WA_FIELDCAT.
      	WA_FIELDCAT-FIELDNAME           = 'LMNGA'.
      WA_FIELDCAT-SELTEXT_L                = 'Cantidad'.
      CLEAR WA_FIELDCAT.
      	WA_FIELDCAT-FIELDNAME           = 'MEINH'.
      WA_FIELDCAT-SELTEXT_L                = 'Unidad de medida'.
      WA_FIELDCAT-OUTPUTLEN         = 15.
      WA_FIELDCAT-JUST = 'R'.
    ENDFORM.                    "CATALEG_ALV
    *  FORM: LAYOUT_ALV                                                    *
    FORM LAYOUT_ALV USING LS_LAYOUT TYPE SLIS_LAYOUT_ALV.
      LS_LAYOUT-ZEBRA             = 'X'.
      LS_LAYOUT-BOX_FIELDNAME = 'CHECKBOX'.
    ENDFORM.                    "LAYOUT_ALV
    *  FORM: FUNCIÓ PER A MOSTRAR L'ALV PER PANTALLA                        *
    FORM MOSTRAR_ALV.
      CALL FUNCTION 'REUSE_ALV_GRID_DISPLAY'
        I_CALLBACK_PROGRAM = G_REPID
        		IT_FIELDCAT = IT_FIELDCAT
        		IS_LAYOUT = GS_LAYOUT
        I_CALLBACK_PF_STATUS_SET = 'SET_PF_STATUS'
        I_CALLBACK_USER_COMMAND = 'USER_COMMAND'
        	TABLES
        		T_OUTTAB = IT_OUT 				.
      	 IF SY-SUBRC <> 0.
    ENDFORM.                    "MOSTRAR_ALV
    *  FORM: SET_PF_STATUS                                                  *
    FORM set_pf_status USING rt_extab TYPE slis_t_extab.
      SET PF-STATUS 'STATUS_ALV'.
    ENDFORM.                    " SET_PF_STATUS
    *  FORM: GENERAR_FICHERO                                                 *
    FORM GENERAR_FICHERO.
      CALL FUNCTION 'WS_DOWNLOAD'
          filename                = TEXT-003
          filetype                = 'ASC'
        TABLES
          data_tab                = IT_OUT
        EXCEPTIONS
          file_open_error         = 1
          file_write_error        = 2
          invalid_filesize        = 3
          invalid_type            = 4
          no_batch                = 5
          unknown_error           = 6
          invalid_table_width     = 7
          gui_refuse_filetransfer = 8
          customer_error          = 9
          OTHERS                  = 10.
    ENDFORM.                    "GENERAR_FICHERO
    *  FORM: USER_COMMAND                                                   *
    FORM USER_COMMAND USING RF_UCOMM LIKE SY-UCOMM
                            RS       TYPE SLIS_SELFIELD.
      CASE RF_UCOMM.
        WHEN 'PROCESAR'.
          PERFORM GENERAR_FICHERO.
          RS-REFRESH = 'X'.
      ENDCASE.
    ENDFORM.                    "user_command
    El problema es que en cuanto le doy al boton de GENERAR me da un error del siguiente tipo:
    Err.tmpo.ejec. MOVE_TO_LIT_NOTALLOWED_NODATA
    Assignment error: Overwriting a protected field.
    The program tried to assign a new value to the field "<L_BOX>" even though
    it is protected against changes.
    La verdad es que no se que hacer...alguien se ha encontrado con lo mismo alguna vez????
    Gracias!
  • nenuke
    • 87
    Prueba a quitar la linea RS-REFRESH = 'X'.
    • su86
      A mi me pasa lo mismo y no se que hacer
      • larmadovr
        • 77
        Que tal:
        Intenta hacer algo como lo siguiente:
        Crea una estructura con los datos de la tabla it_out
        Y despues has lo siguiente:
        TYPES: BEGIN OF st_output.
        INCLUDE STRUCTURE ztablaquetucreas.
        TYPES: END OF st_output.
        DATA: it_out TYPE STANDARD TABLE OF st_output WITH HEADER LINE.
        NOTA: Es muy probable que tu problema es por los tipos de datos, en caso de que no se solucione tu problema me comentas y lo sigo analizando.
        I.S.C.T. Luis Armando Valdez Rodríguez
        Consultor ABAP
        correo: larmandovr@hotmail.com
        cel: (045) 5537406023
        "La vida premia la acción"
        • abapconsultoria
          • 101
          Podrias pegar el dump entero ??
          ABAPCONSULTORIA@GMAIL.COM
          www.consultoriaabap.blogspot.com
          Lo importante no es saber sino saber quien es el que sabe
          • DavidXD_XD
            • 1255
            El problema del programa es el PF-STATUS, dame un toq y t paso como deberias hacerlo
            David Carballido Córdova
            • DavidXD_XD
              • 1255
              Ya ta corregido, el problema era por la constante CHECKBOX que colocabas en el layout.
              REPORT ZPRUEBA_1 MESSAGE-ID SABAPDOCU.
              TABLES: AFRU.
              * TYPES *
              * TYPE-POOLS *
              TYPE-POOLS: SLIS.
              * VARIABLES *
              *VARIABLES ALV
              * TAULES INTERNES *
              END OF IT_AFRU.
              END OF IT_OUT.
              PARAMETERS: P_AUFNR LIKE AFRU-AUFNR. "NÚMERO DE OF
              START-OF-SELECTION.
              G_REPID = SY-REPID.
              FROM AFRU
              LOOP AT IT_AFRU.
              ENDLOOP.
              CASE V_LINES.
              WHEN 0.
              MESSAGE S888 WITH 'No hay nada'.
              EXIT.
              WHEN OTHERS.
              ENDCASE.
              FORM CATALEG_ALV.
              CLEAR IT_FIELDCAT.
              CLEAR WA_FIELDCAT.
              CLEAR WA_FIELDCAT.
              CLEAR WA_FIELDCAT.
              * LS_LAYOUT-ZEBRA = 'X'.
              * LS_LAYOUT-BOX_FIELDNAME = 'CHECKBOX'.
              FORM MOSTRAR_ALV.
              DATA : gt_events TYPE slis_t_event,
              ls_events TYPE slis_alv_event.
              CALL FUNCTION 'REUSE_ALV_EVENTS_GET'
              i_list_type = 0
              IMPORTING
              et_events = gt_events.
              READ TABLE gt_events INTO ls_events WITH KEY name = 'USER_COMMAND'.
              ls_events-form = 'USER_COMMAND'.
              MODIFY gt_events FROM ls_events INDEX sy-tabix TRANSPORTING form.
              CLEAR ls_events.
              READ TABLE gt_events INTO ls_events WITH KEY name = 'PF_STATUS_SET'.
              ls_events-form = 'SET_PF_STATUS'.
              * SET PF-STATUS 'STATUS_ALV'.
              * IS_LAYOUT = GS_LAYOUT
              IT_EVENTS = gt_events[]
              TABLES
              T_OUTTAB = IT_OUT .
              IF SY-SUBRC <> 0.
              FORM SET_PF_STATUS USING rt_extab TYPE slis_t_extab.
              filename = 'C:\texto.txt'
              filetype = 'ASC'
              TABLES
              data_tab = IT_OUT
              EXCEPTIONS
              file_open_error = 1
              invalid_type = 4
              no_batch = 5
              unknown_error = 6
              customer_error = 9
              OTHERS = 10.
              CASE RF_UCOMM.
              WHEN 'PROCESAR'.
              RS-REFRESH = 'X'.
              WHEN 'BACK'.
              LEAVE TO LIST-PROCESSING.
              ENDCASE.
              Cualquier inquietud no dudes en consultar ... suerte !!!
              • viccas
                Solución Alterna
                Yo tuve el mismo inconveniente, y lo solucione, en caso de que si quieras usar las cajas de selección, declarando CHECKBOX en las variables de mi tabla interna, así ya tendremos la opción de seleccionar determinados registros.
                • yisus1988
                  Solución
                  Exacto, yo tuve el problema y lo solucioné como comenta viccas.
                  En la estructura de la tabla que se monta en la ALV, me faltaba declarar el parámetro (SEL) de selección, de tipo CHAR1.
