Todo lo referente a impresion de Codigo de Barras
  • jmadera
    • 6
    me gustaria saber todo lo referente a impresion de codigos de barra en sap
    ademas si existe una transaccion estandar en SAP que permita realizar un match entre un inventario fisico de activos y el teorico existente.
    sobre Activos Fijos
    gracias anticipadas
  • jmadera
    • 6
    sobre codigos de barra
    al parecer es un tema vedado, no hay quien opine sobre el
    23 visitas y ni un ñiiiiiiiiii,
    • aduro
      • 152
      Buscar en SAP ...
      Hola JMadera!
      ... y a veces cuesta encontrar ...
      Ha intentado en SAP ...? http://help.sap.com/
      No se con que version de R/3 estaran Uds. , si busca x ejemplo "Searched for: code bar AND Inventory (Application: SAP R/3 and R/3 Enterprise / Language: English )"
      obtendra una lista de ocurrencias como esta:
      Release
      Bar Code Use (SAP Library - Warehouse Management System (WMS)) - highlight 4.70
      Bar Code Use... consumer product packages, pallets and other containers has become... counters, but also for inventory control and the optimization of stock... In WM, bar code scanning is used,...
      Outputting Bar Codes (SAP Library - SAP Printing Guide (BC)) - highlight 4.70
      Outputting Bar Codes... data for such purposes as inventory of stock, transport, purchase, and so on. Bar codes code data as a series... of lines of varying thickness and/or...
      Storing Physical Inventory Count Results (MM-IM) (SAP Library - SAP ArchiveLink - Storage Scenarios (MM)) - highlight 4.70
      Storing Physical Inventory Count Results ( MM-IM )... in an external content server and linked with the R Subsequent storage with bar code... BUS 2028 ( physical inventory of material )... Preparation and...
      Storing Documents (SAP Library - Inventory Management and Physical Inventory (MM-IM)) - highlight 4.70
      In Inventory Management, you can use SAP ArchiveLink to... goods receipts for purchase orders and goods movements without reference... in Administration Settings ® Activate Bar Code Storage, you specify... to store documents containing physical inventory...
      Mobile Data Entry (LE-MOB) (SAP Library - Mobile Data Entry (LE-MOB)) - highlight 4.70
      ... by speed, reliability, and precision in processing individual... ) numbers, using a bar code ( for example,... Inventory counting Loading and unloading... must then verify by scanning bar codes.
      Predefined Bar Codes (SAP Library - SAP Printing Guide (BC)) - highlight 4.70
      Predefined Bar Codes ( test bar code - inventory management ) information about predefined bar codes and supported printers, see... For bar code printing on device type
      Mobile Data Entry (MDE) (SAP Library) - highlight 4.70
      ... ( for example, via bar-code scanning devices or remote keying ) and post it to the database in the... Entry of physical inventory count results ( for posting in... create a program that receives and...
      Storing Incoming Delivery Notes (MM-IM) (SAP Library - SAP ArchiveLink - Storage Scenarios (MM)) - highlight 4.70
      ... In Inventory Management, you can put incoming print-... in an external content server and linked with the R Subsequent storage with bar code... Preparation and Customizing ( MM-IM ) In Customizing for Inventory...
      RF Device Basic Functions (SAP Library - Mobile Data Entry (LE-MOB)) - highlight 4.70
      ... Enter Function ( Navigation With Bar Code Scanner ).... Confirms a message and leaves the screen... Inventory Counting... Packing and Unpacking... Inventory Counting
      Design Guidelines (SAP Library - BC - SAP Style Guide) - highlight 4.70
      The menu bar and the pull-down... hys. inventory doc.... with path names/transaction codes ( see Accessing a... between a one-line and two-line display... The menu bar...
      Espero le sirva o por lo menos lo anime a seguir buscando en SAP.
      Por lo menos fue algo mas que "un ñiiiiiiiiii" !!
      Saludos!
      Originalmente publicado por jmadera
      Aprendiendo SAP en Consultoria-SAP
      A.Duro
      • wferase
        codigos de barras e inventario de activos
        Esta es muy buena.
        Conseguiste algo por otra via?
        Llevo meses intentando imprimir desde formularios con impresoras ZEBRA no lo consigo.
        • sergiogancedo
          • 6
          Nostros lo hicimos así:
          Una impresora Brother para etiquetas que vale 90€ y el software que traía para imprimirlas.
          El software exigía colocar las descripciones de los materiales del almacen en un excel, así que creamos una hoja excel con el código del material, descripción y ubicación y...listo!
          Espero que os sirva de algo.
          Un saludo
          • joseo
            yo he utlizado este software para generar etiquetas,
            espero les ayude.
            • Juan Luis Mateo Jimenez
              Posibilidades de impresión de códigos de barras en Sap
              sobre Activos Fijos
              gracias anticipadas
              Yo he implantado sistemas de códigos de barras en el Sap de Iberia, distribuidoras de Coca Cola, grandes laboratorios, compañías eléctricas...
              He utilizado software de pago de una empresa austríaca.
              Tiene diferentes programas para hacerlo cuyas peculiaridades se explican en http://www.sicae.es/software/codbarr...roductosap.pdf.
              Si queréis podéis bajar demos totalmente operativas gratuitas y anónimas de http://www.sicae.es/software/codbarras/sap.aspx.
              Todo funciona igual que la versión de pago, excepto que el código generado lleva una etiqueta que pone demo, por lo que es ideal para estudiar el tema sin gastar un euro
              Editado por última vez por Juan Luis Mateo Jimenez; 24/09/2011, 08:48:02.
              • Junior Member
                Re: Todo lo referente a impresion de Codigo de Barras
                Me gustaría saber un poco más del tema tienen algún enlace interesante para ver las posibilidades con respecto a este asunto
                de antemano muchas gracias
                • Junior Member
                  A mi tambien me gustaria aprender un poco m%u00E1s sobre este tema, alguien tiene alg%u00FAn manual para poder profundizar en el tema.
                  Muchas gracias
                  Editado por última vez por jsanz80; 12/04/2021, 06:56:32.
                  • Junior Member
                    #10
                    Tambi%u00E9n quiero profundizar en el tema, si pudieran proporcionar alg%u00FAn manual o mas contenidos con informacion para la implementaci%u00F3n .
                    __________________________________________________ ___________________________________
                    Cursos y desarrollo personal https://todosdesdecero.com/cursos-y-desarrollo-personal/
                    Editado por última vez por preguntasparaask; 24/06/2021, 20:08:04.
