If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Mira Con La Transaccion Mm02 Lo Modificas En Datos Base1 Umb Y Le Das Por Las Que Necesitas Tienes Que Tener En Cuenta La Asignacion Interna Ie El Ean.
