Buenas noches:
Tengo el problema con REUSE_ALV_COMMENTARY_WRITE no muestra la cabecera nose cual es el problema.
REPORT ZALV02.
INITIALIZATION.
TABLES : spfli.
DATA: BEGIN OF ti_tabla OCCURS 0, " crea una variable estructura
carrid LIKE spfli-carrid,
cityfrom LIKE spfli-cityfrom,
distance LIKE spfli-distance,
END OF ti_tabla.
type-POOLS : slis.
DATA: wa_layout TYPE slis_layout_alv.
DATA: ti_fieldcat TYPE slis_t_fieldcat_alv WITH HEADER LINE. "tabla, con un registro por cada campo
DATA: it_listheader TYPE slis_t_listheader,
wa_listheader TYPE slis_listheader.
START-OF-SELECTION.
PERFORM carga.
PERFORM layout.
PERFORM armadosalida.
end-of-SELECTION.
PERFORM build_alv_header.
PERFORM salida.
*& Form CARGA
* text
* --> p1 text
* <-- p2 text
FORM CARGA .
SELECT * FROM spfli INTO CORRESPONDING FIELDS OF TABLE ti_tabla.
ENDFORM. " CARGA
*& Form ARMADOSALIDA
* text
* --> p1 text
* <-- p2 text
FORM ARMADOSALIDA .
CLEAR ti_fieldcat.
ti_fieldcat-fieldname = 'CARRID'.
ti_fieldcat-tabname = 'TI_TABLA'.
ti_fieldcat-seltext_m = 'CARRID'.
ti_FIELDCAT-EMPHASIZE = 'C710'.
ti_fieldcat-col_pos = 2.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
ti_fieldcat-fieldname = 'CITYFROM'.
ti_fieldcat-seltext_s = 'CIUDAD'. " descripcion corta
ti_fieldcat-seltext_l = 'CIUDAD GRANDE'. " descripcion larga
ti_fieldcat-seltext_m = 'CIUDAD MED'. " descripcion media
ti_fieldcat-outputlen = 8.
ti_fieldcat-col_pos = 3.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
ti_fieldcat-fieldname = 'DISTANCE'. " NOMBRE DEL CAMPO DE LA TI
ti_fieldcat-tabname = 'TI_TABLA'. " NOMBRE DE LA TABLA INTERNA
ti_fieldcat-seltext_l = 'DISTANCIAA'. " NOMBRE A MOSTRAR EN EL MENU
ti_fieldcat-outputlen = 20. " longitud del campo
ti_fieldcat-col_pos = 1. " posicion en que columna va estar
APPEND ti_fieldcat.
ENDFORM. " ARMADOSALIDA
*& Form SALIDA
* text
* --> p1 text
* <-- p2 text
FORM SALIDA .
CALL FUNCTION 'REUSE_ALV_GRID_DISPLAY'
EXPORTING
* I_INTERFACE_CHECK = ' '
* I_BYPASSING_BUFFER = ' '
* I_BUFFER_ACTIVE = ' '
I_CALLBACK_PROGRAM = sy-repid
* I_CALLBACK_PF_STATUS_SET = ' '
* I_CALLBACK_USER_COMMAND = ' '
I_CALLBACK_TOP_OF_PAGE = 'top_of_page'
* I_CALLBACK_HTML_TOP_OF_PAGE = ' '
* I_CALLBACK_HTML_END_OF_LIST = ' '
* I_STRUCTURE_NAME =
* I_BACKGROUND_ID = 'IMAGEN_PRUBA' " nombre de la imagen
* I_GRID_TITLE =
* I_GRID_SETTINGS =
IS_LAYOUT = wa_layout
IT_FIELDCAT = ti_fieldcat[] " nombre de tabla alv
* IT_EXCLUDING =
* IT_SPECIAL_GROUPS =
* IT_SORT =
* IT_FILTER =
* IS_SEL_HIDE =
* I_DEFAULT = 'X'
* I_SAVE = ' '
* IS_VARIANT =
* IT_EVENTS =
* IT_EVENT_EXIT =
* IS_PRINT =
* IS_REPREP_ID =
* I_SCREEN_START_COLUMN = 0
* I_SCREEN_START_LINE = 0
* I_SCREEN_END_COLUMN = 0
* I_SCREEN_END_LINE = 0
* I_HTML_HEIGHT_TOP = 0
* I_HTML_HEIGHT_END = 0
* IT_ALV_GRAPHICS =
* IT_HYPERLINK =
* IT_ADD_FIELDCAT =
* IT_EXCEPT_QINFO =
* IR_SALV_FULLSCREEN_ADAPTER =
* IMPORTING
* E_EXIT_CAUSED_BY_CALLER =
* ES_EXIT_CAUSED_BY_USER =
TABLES
T_OUTTAB = ti_tabla " nombre de la taba interna
EXCEPTIONS
PROGRAM_ERROR = 1
OTHERS = 2
IF SY-SUBRC <> 0.
* MESSAGE ID SY-MSGID TYPE SY-MSGTY NUMBER SY-MSGNO
* WITH SY-MSGV1 SY-MSGV2 SY-MSGV3 SY-MSGV4.
ENDFORM. " SALIDA
*& Form LAYOUT
* text
* --> p1 text
* <-- p2 text
FORM LAYOUT .
wa_layout-zebra = 'X'.
wa_layout-Lights_fieldname = '2'.
wa_layout-Window_titlebar = 'Reporte ALV PRUEBA'.
ENDFORM. " LAYOUT
*& Form BUILD_ALV_HEADER
* text
* --> p1 text
* <-- p2 text
FORM build_alv_header .
* Type H is used to display headers i.e. big font
wa_listheader-typ = 'H'.
wa_listheader-info ='Flight Details'.
APPEND wa_listheader TO it_listheader.
CLEAR wa_listheader.
* Type S is used to display key and value pairs
wa_listheader-typ = 'S'.
wa_listheader-key = 'Date :' .
CONCATENATE sy-datum+6(2)
sy-datum+4(2)
sy-datum(4)
INTO wa_listheader-info
SEPARATED BY '/'.
* Type A is used to display italic font
wa_listheader-typ = 'A'.
wa_listheader-info ='SAP ALV Report'.
ENDFORM. " BUILD_ALV_HEADER
*& Form top_of_page
FORM top_of_page.
CALL FUNCTION 'REUSE_ALV_COMMENTARY_WRITE'
EXPORTING
it_list_commentary = it_listheader.
ENDFORM. "top_of_page
REPORT ZALV02.
INITIALIZATION.
TABLES : spfli.
END OF ti_tabla.
type-POOLS : slis.
START-OF-SELECTION.
PERFORM carga.
PERFORM layout.
end-of-SELECTION.
PERFORM salida.
*& Form CARGA
* text
* --> p1 text
* <-- p2 text
FORM CARGA .
ENDFORM. " CARGA
* text
* --> p1 text
* <-- p2 text
FORM ARMADOSALIDA .
CLEAR ti_fieldcat.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
APPEND ti_fieldcat.
CLEAR ti_fieldcat.
APPEND ti_fieldcat.
*& Form SALIDA
* text
* --> p1 text
* <-- p2 text
FORM SALIDA .
EXPORTING
* I_GRID_TITLE =
* I_GRID_SETTINGS =
* IT_EXCLUDING =
* IT_SORT =
* IT_FILTER =
* IS_SEL_HIDE =
* I_DEFAULT = 'X'
* I_SAVE = ' '
* IS_VARIANT =
* IT_EVENTS =
* IT_EVENT_EXIT =
* IS_PRINT =
* IS_REPREP_ID =
* IT_ALV_GRAPHICS =
* IT_HYPERLINK =
* IT_ADD_FIELDCAT =
* IT_EXCEPT_QINFO =
* IMPORTING
TABLES
EXCEPTIONS
PROGRAM_ERROR = 1
OTHERS = 2
IF SY-SUBRC <> 0.
ENDFORM. " SALIDA
*& Form LAYOUT
* text
* --> p1 text
* <-- p2 text
FORM LAYOUT .
ENDFORM. " LAYOUT
* text
* --> p1 text
* <-- p2 text
sy-datum+4(2)
sy-datum(4)
SEPARATED BY '/'.
*& Form top_of_page
FORM top_of_page.
EXPORTING
